Lsvtec swap 232hp all motor
Means of contact: 7578973556 text between 10am - 10 pm
Price: $ 4000 obo
Description:
is split apart right now but have everything to put it back together
Block
all machine work done by abacus
B18 block bored to 82 mm
ls crank
ls eagle rods
weisco 12.8 comp pistons
lightened fly wheel
stage 2 unsprung comp clutch
rotating assembly balanced
golden eagle head studs
golden eagle ls vtec conversion kit
10k on honda oil pump
10k on honda water pump
brand new timing belt
shaved 7 thousandths
Head:
18k miles on head
Recently ported and polished
Port and polish done by earnie
Full skunk 2 pro series valvetrain
skunk2 flat face valves
buddyclub stage 3 cams
buddyclub cam gears
shaved 16 thousandths
has been tapped for ls vtec
red honda valve cover
skunk2 intake manifold
skunk 2 65mm thortle body
both intake and throttle body were port matched to head
Rc 440 injectors
aem fuel rail
High end try i header
trannie:
B16 gears
2000 type r lsd and final
bout 4k miles on tranny
will come with ecu
Many can vouch for this little monster motor and tranny are painted copper
This swap was in a Em1 front end del sol for those who have seen it in action
Price: $ 4000 obo
Description:
Block
ls crank
ls eagle rods
lightened fly wheel
Head:
18k miles on head
buddyclub cam gears
Rc 440 injectors
aem fuel rail
trannie:
B16 gears
will come with ecu
Re: Lsvtec swap 232hp all motor
bump for corey cant tell ya how many times ive been in the delsol with this beast under the hood. sad to see it go :,(
glws animal
glws animal
It's Mr. Nasty Time
bump for mr sears. shit scooted boots when it was in the del sol
