LSvtec kit, Bseries halfshaft,alt,flywheels,headers. p05/06 n more
LS/vtec kit. comes with T and line and tap etc.... brand new in plastic
50$
2 obd1 4 wires o2 sensors, also have a extension with clips on each side incase o2 sensor wires arent long enough to plug into harness
30$ a sensor
10$ extension
2 Stock GSR headers. 1 is obd1 94-95 teg w o2 bung, other is 96-01 bod2 gsr shorter one w/o 02.
40$ a header
PIPING- I have a bunch of piping, intake pieces, intercooler piping, couplings etc...just a bunch of collected stuff.-----LMK what ya need. 2 in 3 in coupling w.e
GSR iacv. perfect working order . have lines and bolts as well.
30$
92-95 oem complete airbox set up.
60$
2 Jdm Gsr flywheels. mint. prolly 50k on both
70$
Bseries Halfshaft.
40$
Gsr obd1 altenator. Perfect shape. Also have brackets as well.
60$
95 gsr waterpump. Used 40k miles
20$
2 bseries exhaust manifold gasket 1 brand new 1 used
25$ new one
15$ old one
Jdm Gsr stock oem headbolts.
- came off my jdm gsr swap first time it was takin apart
25$
IACVS, tbs, lines etc. got a box full of dseries and bseries parts.
$ lmk what ya need.
Bseries oil dipstick. Good shape
20$
Ls/b20 valve cover gasket. Brand new
30$
Bseries 3 bolt driver side mount bracket. Off gsr. W bolts.
20$
Bseries rear block to trans bracket
10$
Bseries hyrdo clutch. Aftermarket replacement. Came on my gsr motor. 50% life left.
30$
Bseries pilot bearing. Brand new. Came with clutchkit
10$
1 B series 2 dseries clutch cables 88-91 civic
15$ a piece
d16z6 valve cover painted like the japanese flag red/white
25$
3 92-95 civic fuel line. oem. from filter to rail
15$
Bseries stock gsr fuel rail. fresh
15$
Bseries stock injectors gsr fresh obd1
40$
2 bseries flywheel covers.1 ls 1 gsr
20$ a piece
2 D series 2 bolt drivers side motor mount brackets and one driver side mount
20$ brackets 30$ mount
2 b series intake manifold brackets. 1 ls 1 gsr
15$
2 sets bseries vtec stock sparkplug wires. fresh
30$ a set
MSD coil to cap wire. BNIB
10$
Bseries eg t bracket. use with bseries trans in 92-95 civic
40$
Bseries vtec. Upper inner timing belt cover.
20$
Coolant hoses, rad hoses, vacuum hoses. I have a box full of all of it
$ lmk what you need
ECU's:
1. Pm6 ecu obd0
30$
2. p05 obd1 sohc
50$
3. po6 obd1 - perfect for hondata
50$
info:
Contact- CODY - 443 220 7142 CALL/text or pm/reply
50$
30$ a sensor
10$ extension
40$ a header
30$
60$
70$
Bseries Halfshaft.
40$
60$
20$
25$ new one
15$ old one
25$
$ lmk what ya need.
20$
30$
20$
10$
30$
10$
15$ a piece
25$
15$
15$
40$
20$ a piece
15$
30$ a set
10$
40$
20$
$ lmk what you need
ECU's:
1. Pm6 ecu obd0
30$
2. p05 obd1 sohc
50$
50$
info:
Jarrod
Engine / Exhaust / Drivetrain
23
01-21-2010 12:31 PM
h23havoc
Want to Buy / Trade ARCHIVE
05-07-2008 06:09 PM
