LSV/B series parts
1 Attachment(s)
Location: Newport News/Hayes, VA Means of contact: Phone (757-812-5917) or PM Im trying to sell my LSV setup. I will sell everything listed as a whole for $1000. Otherwise the price is listed next to the part. I am not really looking to trade for anything right now, but you're welcome to offer. Specs on the LSV are as follows: B18B/B16 ~25k miles on engine rebuild ACL bearings New pistons/rings New oil/water pump Cometic head gasket Golden Eagle head studs GSR cams Single belt crank pulley Skunk 2 intake manifold Omni 68mm throttle body Phenolic intake manifold and throttle body spacers Moroso baffled oil pan New distributor New NGK plugs/wires PLM hytech replica header New OEM vtec solenoid gasket New OEM valve cover plug and gasket If you want to buy things separately, prices are as follows: Skunk 2 Manifold (For B16/ITR) - $150 Omnipower 68mm Throttle Body - $100 LS Cable transmission - $200 -High RPM 3rd gear grind when shifting quickly OBD 1 VTEC Distributor - $100 PLM Hytech Replica header - $200 -Has some dents due to being close to the ground Phenolic intake manifold/Throttle body spacers - $50 LSV Long Block - $500 (Long block does not include distributor, injectors, header, intake manifold Attachment 188648 |
Re: LSV/B series parts
Bump
Bump
Bump
Sell clutch?
