Lots of B series and D series EK and DC parts. Aftermarket and stock. Part I.
AaronDavis
Means of contact: TEXT 757-642-7541
Need this gone! Please make offers, anything resonable will be taken
B16 Head with new valve seals. Fresh from Abacus Machine Shop. $400
B16 Intake manifold with Throttle body with map sensor and tps $100
B16 cams no gears. $50
GSR Intake manifold with IAB's and solenoid. $75
Vtec solenoids. 1 d series and 2 b series I think. $20 each.
3 P30 AC brackets. One with good torque mount. $40. 2 without torque mount. $30 each.
Tranny torque mount. B series. $40
Injector resistor box with injector plugs. $75
GSR exhaust manifold and downpipe with heat shields $40
3 GSR pistons and rods from JDM GSR with about 40K miles. $30
JDM GSR crankshaft with about 40K miles $100
B series (No name) header with flex pipe and a short resonator. The flex pipe has a hole in it and will need to be replaced. This header has been on an EK with a B16 and also an Integra GSR $60.
IAC Valve from a B20. I thought it was a bad part causing a running issue. I thought wrong so I assume it's still good. $40.
B20 distributor cap and rotor and spark plugs. I also thought these were a problem but ended up not being it too. $20
AC pressure swith from EK. $5
Stock B series fuel rail from a GSR with injectors and fuel pressure regulator. $50
Stock B series fuel rail with fuel pressure regulator. No Injectors. $25.
B20 throttle body with map sensor, tps, and FITV that's been cleaned and tightened already. $40
GSR throttle body with no sensors. $20
BoBo short ram intake. Has a cut pipe from a cold air intake, a spectre coupler, and a spectre filter. Had is on a GSR with ABS. $25.
No name adjustable fuel pressure regulator. Never had it on a car, looks like a universal no name. $20
B16 distributor for parts only. I took the ICM off of it and put a bad one back in it. If you want to fix it it'll probably work. $20.
REXsi90
Engine / Exhaust / Drivetrain
24
03-12-2012 10:15 AM
abmcheckmate
03-01-2012 03:29 PM
