K24Z1 block, crank, chain gaurd, oil pan and other parts
Means of contact: Send a pm
Price: $300 obo
Description:K24Z1 block, crank, oil pan, and chain cover. Comes with a cnc'd aluminum block off plate for original oil filter location so that it can be ran like the older K20's and K24's. Is missing one of the factory plugs, which is pictured (part # 11106-PNA-300) and needs the stud for the oil filter. Both items are available through Honda. All of these parts are in good shape. This block was swapped under factory warranty after the customer complained of a loss in power. Turns out the engine was nearly hydrolocked after the customers kid took the vehicle offroading. The engine was in mint shape other than one slightly bent rod. The main bearings are still in the block and are in good shape as well. I was going to build it but changed my plans.
Asking $300
Some K24 rods and pistons. First set are K24A1 and has a piston missing. Second set are K24Z1and has a rod missing.
Asking $50 for all or $25 a set.
Send me a pm if you need more info or better pics. I also have some other parts lying around that are not getting used. Maybe I have something you need.
Pictures:
Price: $300 obo
Asking $300
Pictures:
wingzeroac195
Engine / Exhaust / Drivetrain
02-28-2012 10:49 AM
chevylowrider21
16
03-04-2011 07:58 AM
methods
06-09-2009 03:58 PM
