JDM ITR head/block/trans, JDM GSR head/block, Greddy D-series kit, Hondata S300, more
PM, SMS (410-505-8592), or email (jesse at hondatwincam dot com) is the best way to reach me.
Perrin catch can
- MSRP $130
- $100
- a couple of pics, more here http://hondatwincam.com/fs/perrin/
1-piece S2000 axle / driveshaft spacers
- 1 piece aluminum
- unknown brand
- $50 + shipping OBO
S2000 Hard Top Strikers
- BNIB
- fix your soft top wind noise
- $60 shipped
1997 JDM Integra Type R head
- intake manifold, throttle body, fuel rail, injectors, distributor, plug wires, spark plugs
- ITR exhaust cam, CTR intake cam
- all cam caps, oil spray rails, bolts, COMPLETELY COMPLETE
- $900
- couple of pics, the rest are here: http://www.hondatwincam.com/fs/97jdm_itr_head/
1997 JDM Integra Type R short block
- nothing missing at all
- either #2 or #3 needs new rings, I forget which was low on compression - will disclose to buyer
- $800
- couple of pics, the rest are here: http://www.hondatwincam.com/fs/97jdm_itr_block/
1997 Integra Type R transmission
- 4.4 final w/ LSD
- no grinds, pop-outs, it's in great shape
- slight cosmetic damage to bolt holes for front mount. Threads are fine
- will include extra gear sets (3/4)
- $950 --pending--
- couple of pics, the rest are here: http://hondatwincam.com/fs/97jdm_itr_trans/
1997 JDM GS-R head
- Blox intake manifold, bored OEM throttle body, fuel rail, injectors, distributor, plug wires
- both cams, all cam caps, oil spray rails, bolts, sensors, COMPLETELY COMPLETE
- $600 --pending--
- a couple pictures, the rest are here: http://www.hondatwincam.com/fs/97jdm_gsr_head/
1997 JDM GS-R short block
- still has 00 pistons but it's been apart as the pistons are assembled backwards (arrows point the wrong way)
- compression #s were good but I'd do a hone, re-ring, and re-assemble the pistons correctly (at least)
- $550 --pending--
- a couple pictures, the rest are here: http://www.hondatwincam.com/fs/97jdm_gsr_block/
ARP head studs for D16Z6
- used once
- $80
Hasport mounts, linkage, etc. for hydro B-series swap into EF
- $300 --pending--
Powercore exhaust manifold
- B-series fitment
- 4-1 design, 2.5" collector
- stainless steel
- not some POS cheap Chinese junk
- $150
- some pics, all others here http://hondatwincam.com/fs/pc4-1/
JDM ITR catalytic converter
- flanged to work w/ 2.5" collector
- $100
2.5" test pipe
- non-resonated
- $50
Greddy 52mm boost gauge
- $60
Greddy 52mm oil pressure gauge
- brand new
- $85
OBD1 harness to OBD2 Injector adapters
- brand new, 4 pieces
- plug an OBD2-style injector into your OBD0/1 harness
- $50
Virgin ODB1 P72 GS-R ECU
- $120
- larger versions of this pic here: http://hondatwincam.com/fs/ecus/p72.JPG
Virgin JDM P73 Integra Type R ECU
- $140
- larger versions of this pic here: http://hondatwincam.com/fs/ecus/p73.JPG
Kenji chip for socketed/chipped OBD1 ECUs
- Keni ITR tune w/ 5300 VTEC and 9000 redline
- This is just the chip, no ECU included!
- $30
Autometer mech. oil pressure and oil temp gauges
- used, no instructions
- $50
Batch of EG Civic instrument clusters
- 1x CX or VX (?) cluster with tachometer
- 1x CX or DX (?) cluster. No tach.
- 1x JDM Si-R cluster
- misc. extra cluster parts, a complete tachometer unit, wiring, speedo parts, etc.
- SOLD AS IS I don't have an EG to test these in so I can't guarantee that everything works. The Si-R cluster, for example, looks like the wiring is a little damaged.
- $200
- one pic of almost everything, more here: http://hondatwincam.com/fs/eg_clusters/
Greddy Turbo timer
- brand new
- SOLD
Moroso breather tank / catch can
- brand new
- the same tank used in the Endyn kit
- SOLD
ARP head studs for B18C
- brand new
- SOLD
ARP head studs for B16A
- brand new
- SOLD!
Hondata S300
- installed in a P28
- boost controls, no BBG though
- SOLD!
Greddy turbo and manifold for D-series
- just the turbo (TD-04H, no shaft play) and manifold
- manifold is coated black
- SOLD
Greddy turbo kit for 1996-2000 D-series
- SOLD!
Y21 transmission
- transmission from '97 Del Sol VTEC
- perfect shape.
- SOLD!
S4C transmission
- transmission from '99 Civic Si
- perfect shape.
- SOLD!
1999 B16A2 long block from Civic Si
- ~40k miles on everything, super clean!
- SOLD!
Perrin catch can
- MSRP $130
- $100
- 1 piece aluminum
- unknown brand
- BNIB
- $60 shipped
- $900
- $800
- 4.4 final w/ LSD
- $950 --pending--
1997 JDM GS-R head
- $600 --pending--
- $550 --pending--
- used once
- $80
- $300 --pending--
- B-series fitment
- stainless steel
- $150
- $100
2.5" test pipe
- non-resonated
- $50
- $60
- brand new
- $85
- $50
- $120
- $140
- $30
- $50
- $200
Greddy Turbo timer
- brand new
- SOLD
- brand new
- SOLD
- brand new
- SOLD
- brand new
- SOLD!
Hondata S300
- SOLD!
- SOLD
- SOLD!
Y21 transmission
- perfect shape.
- SOLD!
S4C transmission
- perfect shape.
- SOLD!
- SOLD!
NAZI mod
Re: JDM ITR head/block/trans, JDM GSR head/block, Greddy D-series kit, Hondata S300,
PM me lowest $ picked up on the type R trans.
Updated list, added pics.
Pm me details about the chipped p28 itr tuned ecu.
i have a fully built b16 bottom end eagle crank eagle h beam rods and 12.5:1 dome pistons. ive decided to go all matching motor. is ur gsr bottom end open for trades? my bottom end has 250 miles on it and i dont mean 250,000.
Hi, thanks for posting. I'm not really interested in any trades. I'm pretty much done with the B-series stuff at this point.
How much for just the jdm si cluster
I'm really just trying to sell the whole lot of clusters. $200 for all of them. The JDM clusters go for almost that much on their own!
Oh, and Greddy kit sold!
no pic of the most expensive thing listed? need pic of trans thx
Sorry for the delay, pics of ITR trans added as well as some other pics.
