JDM B16 motor - Complete swap for EF
Hereeeeesss Beezyy!
Chris Conley
Portsmouth, VA
Contact through PM's or posts in this thread
Price - $2500 OBO / trades may be accepted. Let me see what you've got.
Ive got a complete JDM B16 swap for sale. It has been converted to OBD-1. Motor has GSR cams in it. This motor is really strong and has had all scheduled maintenance. It is pretty much swap, plug, and play for any EF.
Swap comes with:
- COMPLETE B16 (meaning exhaust manifold, distributor, plug wires, alternator, vtec solenoid, intake mani w/ fuel rail, injectors, throttle body, all sensors, INCLUDED.)
- Cable S1 transmission, starter, clutch cable (if needed)
- Clutch is a Stage 4 Centerforce. Flywheel is stock.
- Both axles + half shaft.
- OBD-1 ECU (PR3)
- OBD-1 Jumper Harness
- Engine Harness (if needed)
- Hasport Motor Mounts (to put a B-Series into an EF)
- B-Series Shift Linkage
Motor has a brand new head gasket, brand new oil pan gasket, brand new timing belt, and a brand new water pump, all done 100 miles ago.
Portsmouth, VA
Swap comes with:
- OBD-1 ECU (PR3)
da dragva kokopelli
Re: JDM B16 motor - Complete swap for EF
gl with sale chris,
will vouch for all the maintenance and this motor. well taken care of. never saw vtec since i ever seen it.
