Hydro b18 ls transmission w. shift linkage. starter. clutch
Means of contact:4072868363
Price: $400 firm
Description:I have a ls hydro trans that I pulled from a car. when i pulled the trans to the car the recent owner didnt bolt up the 2 12mm bolts that hold up the linkage so the shift linkage was all over the place. also the tranny was about half way full. the trans didnt have a grind when i sold the trans to recent owner, But when i was driving the car back it had a lilttle notch in 3rd gear but not like a normal grind. so it could be the fact the 2 12mm bolts werent hooked up or it was low on fluid, worse case it could be a syncro , the trans will come with shift linkage which has dual bend shifter, b series starter, b series exedy clutch
Price: $400 firm
cars
Engine / Exhaust / Drivetrain
02-19-2010 09:51 PM
TYPE JDM
01-21-2010 05:47 AM
