Honda parts. Garage clean out
fuck this shit
Means of contact: text (757) 708-5727
Price: $see below. Everything is best offer, but be reasonable.
Description: It's finally time to get out of the game for a while. I have a bunch of stuff, and if you need anything specific, just ask, I may actually have it.
IAC valves
2 GSR IAC valves. $50 each, $80 for both.
1 LS IAC valve. $40
Shift linkages/bushings/etc
One B-series in del sol linkage. $140
One single cam EK shift linkage. $40
One set of brand new out of box Energy red b-series bushings. $25 for them
Suspension parts
2 front top hats off of a DC Integra. NO bushings or hardware. $15 bux each or $25 for both.
2 Eg/EK/DC front (stock) suspension forks. $15 each, both for $20
1 set of EK (stock) rear lower control arms. $20
1 set of EG (stock) rear lower control arms. $20
1 EG front (stock) sway bar. $35
1 aftermarket rear sway bar with bushings and end links. Believe its 27mm like itr. $50
1 rear tie bar for EG/DC. No-name thing. Never used, might have one chip in it. It's silver. $40
1 silver lower subframe brace. No-name, just like ASR. hardware included. $80
Engine parts
1 D series vtec solenoid $30
1 B series vtec solenoid $50
1 complete LS head minus intake mani and dizzy. $50
1 OBX underdrive pulley for d-series I believe. $60
Mounts
Crappy e-bay mounts. B series in EF/ED. Used but not completely trash. $50
3 bolt stock integra mount bracket and stock mount. $50
3 bolt stock integra mount, no bracket. $20
1 set STOCK EK/CRV mounts. $80
2 EG/DC transmission mounts. STOCK. $30 each
Wiring harnesses, misc, and junk
1 COMPLETE UNCUT obd1 GSR wiring harness. $175
1 cut up ek harness. missing alternator plug and some other stuff. $20
1 d-series driver side axle with nut. $50
Misc timing covers, both d and b series. Negotiable
Full stock valve set from a GSR head. $100
1 set LS cams. $40
Misc rear of engine coolant bypass tubes with thermostat housings. $20 each
2 b16 AC compressors. $60 each
Again, please ask me if you need/want anything I haven't listed. I'll do my best to keep this updated.
Pictures: please text me for photos, as this thread will be continually updated as stuff sells or I find new stuff to add to it.
IAC valves
1 LS IAC valve. $40
Suspension parts
Engine parts
Mounts
1 set LS cams. $40
fuck this shit
