GARAGE CLEAN OUT! $100 or less-Exhaust, cams, cranks, blocks n more!
Contact: PM, or Cell 904-422-6402
I prefer local pickup, but will ship some items.
I am cleaning out my garage and trying to get rid of a lot of parts that i have laying around.
50 - GSR Cams
40 - B16 Cams
50 - B16 Crank
60 - LS Block
60 - B16 Block
15 - Stock B series pressure plate
40 - B series starter
40 each (2) Alternators
90 - OEM AC Compressor
30 - OEM AC condensor w/fan
10 - LS/B16 oil pan tapped for oil return line NON AN fitting. Must use rubber hose.
20 - Stock B series flywheel cleaned and resurfaced
5 - RSX-S gator belt for a JRSC 7-9lb pulley
50 - GSR Cams
40 - B16 Cams
50 - B16 Crank
60 - LS Block
60 - B16 Block
Re: GARAGE CLEAN OUT! $100 or less-Exhaust, cams, cranks, blocks n more!
i have a obd1 gsr dizzy with that cap coil and rotor work? what else do i need to hook it up i have an oem dizzy btw thanks!
