FULLY BUILT JDM H22 FULL SWAP!! 264hp ALL MOTOR.
Means of contact: 757-254-5458
Price: $1
Description: Hey Im Looking To sell My Fully Built JDMH22 and Everything you need to swap it, It Came Out Of a Stanced and wire tucked EG Coupe with full suspencion And stance mindset wheels That I currently have for sale also, This Motor has everything you could possibly need to swap it and then some, It Was Built with the highest quality parts i could get and is virtually bulletproof, it was tuned on chrome and made 264hp all motor before i pulled the motor and went sleeved with a forged rotating assembly, tune is still good for the new setup and the motor is fresh from the machine shop with zero miles, I have Lost All interest in the Honda Game so im selling my whole car starting with the motor. if your interested in a stanced and wire tucked h ready eg coupe roller you can contact me for that also, HAVE DOCUMENTATION ON EVERYTHING. And Onto the Motor.
BLOCK: JDM H22A
-Darton Dry Sleeve(closed Deck)
-CP 12.5/1 Pistons(CP Rings)
-Eagle Forged Rods (ARP2000 bolts)
-Eagle Forged Crank.
-YSK Main Girdle.
-ARP Main And Headstuds.
-Block Sleeved,Decked,Honed, Main Line Honed, Hot Tanked.
-ACL Race Bearing Set.
-JDM H22 Oil Pan.
-New OIl pump,Water pump,Oil Pick up Tube and oil Squiters.
HEAD: H22 Type S (agressive Valvetrain)
-Cometic Head Gasket.
-Disassembled and ported.
-NEW Valves,Springs,Retainers,Seals(Oem size)
-Type S Cam shafts.
-Fidanza Lightweight adjustable cam gears.
-New Cam seal.
-Internal coil Dizzy.
-NGK Cold Plugs And Wires.
-H23 Blue top vaalve cover(Cam Gears open)
-New Valve Cover Gasket Set.
-New Timing Belt.
Bolt Ons:
-Venom Log Intake manifold
-Blox 70mm Throttle Body
-Blox TPS
-OBX 7/8 Fuel Rail.
-Blue Top 450cc Injectors.
-Kaizan Speed Balance Shaft Eliminator Kit.
-AEM Swap Intake Tube.
-Spectre 10" Air Filter.
-Full 2.5" Exhaust From the collector to a black vibrant racing muffler
-4-2-1 1.25" megan racing header
-Type R Crank Pulley.
Tranny: USDM H22 Tranny
-Perfect No grinds, popouts, shifts like butter.
-Exedy Stage 2 Clutch.
-Fidanza Lightweight Flywheel.
-Shifter Plate.
-Cables For Tranny.
MISC Extras:
-3 Core Aluminum Full Size Radiator.
-Gates Racing Radiator Hoses (red)
-Nos Nitrous Kit 100 shot pill.(never used you will need a bottle)
-Crane Cams External ignition system.
-Tucked OBD1 Wire harness.
-Full Exhaust
-Dyno Tuned p28. 264hp n/a(Chrome)
-D.S.S 2.9 600hp Axles
-Solid Motor Mounts
-OBX Fuel Pressure Regulator.
-Enough Steel Braided Hose to Fill The Engine bay.
I know im probably forgetting some things but you get the just of it, ive invested a ton of money and time into this motor, it is extremely powerful and bulletproof as well, It comes With Absolutely Everything you need to put it into a car and start it, im asking $3500 OBO for Everything, I feel this is a great price because if i were to add it all up i probably have 7k into the motor alone, May take trades for something of equal value. you can contact me at 757-254-five4five8 or reply to the add. Thanks for looking.
Pictures:
TEXT FOR PICS. OR Additional Information.
Price: $1
BLOCK: JDM H22A
-YSK Main Girdle.
-JDM H22 Oil Pan.
-Type S Cam shafts.
-New Cam seal.
-New Timing Belt.
Bolt Ons:
-Blox TPS
-OBX 7/8 Fuel Rail.
-Shifter Plate.
-Cables For Tranny.
MISC Extras:
-Full Exhaust
-Solid Motor Mounts
Pictures:
Re: FULLY BUILT JDM H22 FULL SWAP!! 264hp ALL MOTOR.
Pictures of the block,crank, main girdle and arp studs will be up soon, all these parts are still at the machine shop, as soon as there done everything is getting cleaned and assembled.
also radiator is brand new in the box so it isnt pictured either, comes with red slim fans
Digital Life
No way your hittings 260s with that valve train and some obx parts on a jdm H22. Surprised no tourqe numbers were put up for shits. Whats next? Tuned by Chris Miller? Glawls
Lol still up, have dyno sheet and video, full documentation, I will part the long block, but I'm not selling it cheap, let's keep the offers comming
