B18B1 Block ($140) + Misc. B-series Parts
Location: Leesburg (Northern VA) Contact: PM Complete B18B1 Block - $140 OBO 160k miles, ran great until the water pump seized and snapped the timing belt. This occurred at < 2000 RPMs and thus there was no detectable damage to the motor - as far as I can tell there was no piston-to-valve contact; this was verified by removing the head, which has already been sold to a satisfied buyer. Piston/rod assemblies were removed, numbered, and bagged; this also allowed me to see that both the crank and rod journals are in great condition - this motor never saw rod knock; always ran 87 octane, never advanced the timing. What you get: Block (w/main caps), crank, pistons, rods, oil pan, PCV breather box, stock oil pump/F&R main seals if you want them. ------------------------------------------------------------------------------------------ 94 Integra parts: - B-series half-shaft $old - Stock flywheel - $15 - PS Pump - $25 - A/C Condenser Fan - $10 - Timing Covers (pretty beat up) - $5 Other parts: - B20 Crank pulley - $10 |
Re: FS: B18B1 Engine + Misc. B-series Parts
PM MME THE LOWEST YOU WILL GO ON THE b18 b
