Fresh jdm b16a head
Fresh jdm b16a head
Means of contact:7575828409 text
Price: $ 300 for bare head with b16 cams or 375 with Gsr cams. Also have a GSr obd2 dizzy(will work with obd1 if you re pin) TRADES: all motor b series vtec cams. Stage 1. Gsr aftermarket intake manifold and throttle body. Or a high flow b series header.
Description: hey driven I have a jdm b16a head with new valve seals, head was resurfaced and cleaned by a local machine shop, it came off my b20vtec set up so till has the plug and pins. I have 2 sets of cams that can go with it. Also have a skunk2 rep intake manifold and a GSr dizzy. Head is super fresh . Has about 60k miles. Came off my b16a swap I bought last fall from Jei. I'm up for trades
Pictures: Doing this from my phone will get pics up aoon
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
