Fresh CNC GSR Sleeved Short Block and P&P Head (zero miles)l
Means of contact: 410-507-5122
Price: $ 3,000 SHORT BLOCK COMPLETE
Description:
($3,000) GSR B18C1 SLEEVED BLOCK: AEBS SLEEVES, 84MM 12.5:1 MANLEY PISTONS, EAGLE RODS, POLISHED AND BALANCED CRANK, DECKED, ACL RACE BEARING, TIME CERTS FOR TRANS BOLT HOLES. MACHINE WORK DONE BY CNC Engine Dynamics & ASSEMBLED BY CCT. ZERO HOURS AND STILL IN THE BUILD BAG AND NEW EVRYTHING. INCLUDED 84MM GE HEAD GASKET.
Priced out:
$2,500 FOR BLOCK AND CRANK
$500 FOR MANLEY PISTONS
$200 FOR EAGLE H BEAM RODS
$100 GE 84MM HEAD GASKET
($1,300) GSR B18C1 HEAD ASSEMBLY. CAMS AND SKUNK2 CAM GEARS. FRESH POLISH AND PORTED, NEW SUPERTECH OVERSIZE VALVES (NOT FLATTOP’S), NEW SUPERTECH SPRINGS AND NEW RETAINERS. NEW VALVE GUIDES. JAMES WILSON BUILT. ZERO HOURS AND STILL IN THE BUILD BAD. INCLUDED NEW GE GSR HEAD STUDS AND VALVE COVER.
PRICED OUT:
HEAD $1,000
CAMS AND CAM GEARS $200
GE HEAD STUDS $100
($800) FUEL DELIVERY SYSTEM: NEW EDELBROCK VICTORX, NEW FULL BLOWN 340 FUEL PUMP, NEW ID 750'S, HONDA 65MM TB, NEW TPS, FUEL RAIL AND PRESSURE REGULATOR (NO NAME) AND B&G FUEL FILTER.
PRICED OUT:
VICTOR X: $225
FB FUEL PUMP: $160
ID 750'S: $400
HONDA 65MM TB WITH SENSORS $100
RAIL AND FP REGULATOR: $100
($1,300) GSR TRANS WITH NEW QUAIFFE DIFF. RECENTLY REBUILT <100 MILES. BNIB COMPETITION STAGE 5 CLUTCH AND BNIB COMPETITION LIGHTWEIGHT FLY WHEEL.
TRANSMISSION: $1000
CLUTCH: 300
FLYWHEEL $150
REASON FOR SALE: GOING NSX ROUTE
CONTACT TOM 410-507-5122
Pictures:
[ATTACH=CONFIG]149404[/ATTACH][ATTACH=CONFIG]149401[/ATTACH][ATTACH=CONFIG]149405[/ATTACH][ATTACH=CONFIG]149406[/ATTACH][ATTACH=CONFIG]149403[/ATTACH][ATTACH=CONFIG]149407[/ATTACH][ATTACH=CONFIG]149402[/ATTACH]
Description:
Priced out:
PRICED OUT:
HEAD $1,000
GE HEAD STUDS $100
PRICED OUT:
VICTOR X: $225
FB FUEL PUMP: $160
ID 750'S: $400
TRANSMISSION: $1000
CLUTCH: 300
FLYWHEEL $150
Pictures:
Re: Fresh CNC GSR Sleeved Short Block and P&P Head (zero miles)l
sale pending on everything in post plus the shell posted on my other thread. FYI, Offer was 10k and deposit recieved this morning
