DSM parts! Hahn turbo kit/ AEM 13" brakes/ carbon hood/ 18" oz ultraleggeras/ more!!!
RCKTMAN
Means of contact: pm/post/call/text 804-239-4047
Price: $listed or trade.
Text for more pictures
Hahn Racecraft turbo kit for 1995-1999 Mitsubishi Eclipse and Eagle talon.
Retails at $3500
I'm asking $1000 for the turbo kit AND fuel management.
Turbo kit consists of:
Turbo- super 16g (s16g) with Fresh rebuild from HAHN with ZERO MILES
Manifold
Piping
Couplers
Wastegate
What you need:
Bov
Downpipe
Water/oil lines
I also have a complete TurboSpecialties fuel management system. Retails at $500
Comes with:
Brain box
Display/control unit
Wire harness
Injection unit
FMU
Wire diagram
I have a set of 13" FRONT AEM rotors with four piston Brembo calipers. This is their STAGE 2 KIT. The setup retails for $2500. The calipers have a burnt orange powdercoat. This setup is for a 2g Eclipse and Talon. Came off of a FWD, may fit AWD. Rotors are perfectly straight. Have been off my car for about a month. Great looking and performing setup! I'm asking $800
I have a carbon fiber hood that fits 95-99 Mitsubishi Eclipse and Eagle Talon.
retails at $600
Asking $75
It is not in the best shape. Has two scratches in the middle. The front left corner is slightly banged up. The right edge has some spider web cracks.
I have an intake manifold from a 95 420a eclipse. Has sensors and throttle body and fpr.
Asking $40
Ported throttle body for a 420a car. I will get measurements tonight. $20
18x8 OZ Ultraleggera. 5x114 bolt pattern. These retail for $350 a piece ($1400 a set)
The tires are all mix matched. One is almost new. I have 3/4 centercaps. You can get a new one on tirerack for $10.
Have a little bit of curbing and a few rock chips. Still in good condition.
Asking $700 or stock eclipse wheels and $500 cash
ACCEPTED TRADES
turbo parts (420a)
All motor parts (420a)
Cams
Front mount intercooler#
Suspension
Exhaust#
Bottom end (built)
Head (built)
Megasquirt ecu (full standalone)
Under drive pulley
Downpipe to a s16g Hahn turbo kit
Wideband
Gauges (must all be matching)
5-speed swap complete with ecu for a 99
Built engine or engine parts
2.4 block (or swap) with mount for an eclipse
Crx or ef hatch
Other wheels
IMG]http://img.tapatalk.com/4bc0a939-7e4f-875f.jpg[/IMG]
Retails at $3500
Manifold
Piping
Couplers
Wastegate
What you need:
Bov
Downpipe
Water/oil lines
Comes with:
Brain box
Wire harness
Injection unit
FMU
Wire diagram
retails at $600
Asking $75
Asking $40
ACCEPTED TRADES
turbo parts (420a)
Cams
Suspension
Exhaust#
Bottom end (built)
Head (built)
Under drive pulley
Wideband
Crx or ef hatch
Other wheels
