D16Z6 Long Block/Short Block/Head
Old 10-20-2011, 09:16 AM
Ahlex's Avatar
Ahlex has disabled reputation
Default D16Z6 Long Block/Short Block/Head
Means of contact: PMs
Description: Looking for a new motor, D16Z6. I'd prefer a long block but will consider a short block and head if I can get sellers from both items quickly.
Please PM me with condition and if any problems.
Thanks
Ahlex is offline
Old 10-20-2011, 10:55 AM
Abad420kid's Avatar
Abad420kid has disabled reputation
Default Re: D16Z6 Long Block/Short Block/Head
i have the z6 head if you can find a block.
Abad420kid is offline
Old 10-20-2011, 11:02 AM
QUOTES YOUR DUMBASS
unuzual kustum's Avatar
unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum unuzual kustum
I have a full d15b7 motor. Would be great with the head above for a mini me swap.
unuzual kustum is offline
Old 10-20-2011, 06:09 PM
Ahlex's Avatar
Currently only interested in a D16Z6, but if I change my plans, I'll let you know. Thanks
Ahlex is offline
Old 10-21-2011, 02:05 AM
QUOTES YOUR DUMBASS
B7 bottom with Z6 head same as Z6.......
Old 10-21-2011, 05:11 AM
Digital Life
83Stang5.0's Avatar
No it's not.
83Stang5.0 is offline
Old 10-21-2011, 08:02 AM
QUOTES YOUR DUMBASS
Originally Posted by 83Stang5.0
No it's not.
Why is that? Just because the mini me bumps up compression? Or because it's a destroked 1.6L and possibly can substain a slightly higher rev? Seriously it's the same.
Old 10-21-2011, 09:03 AM
Digital Life
83Stang5.0's Avatar
as well as a host of other reasons things are changed to even run the damn thing "properly".
Old 10-21-2011, 09:45 AM
QUOTES YOUR DUMBASS
Changed? I take it you have never done one or atleast did it "properly".
Off topic but whatever:
Mini me swap....
D16Z6 Cylinder Head (Including distributor cap, valve cover, plugs/wires, VTEC solenoid, etc)
D16Z6 or D16Y8 Head Gasket
P28 ECU
D16Z6 Timing Belt
D16Z6 Intake Manifold (optional)
D16Z6 Exhaust Manifold (optional)
*If you remove your manifolds, make sure you get new gaskets
D15 bottom end
Make sure you remove the oil plug between cylinder 2 and 3 or no vtec will happen. I would also recommend the y8 plugs due to the compression bump but not necessarily needed. He has everything needed except a bottom end. Which I have a whole b7 motor hence the reason I posted it here. Simple as that. I've done this quite a few times. OP let me know if you are interested.
Old 10-21-2011, 11:19 AM
efnitup's Avatar
efnitup efnitup efnitup efnitup efnitup efnitup efnitup efnitup efnitup
i have a built d16a6 with a d15z1 head
efnitup is offline
Quick Reply: D16Z6 Long Block/Short Block/Head
