D15Z1 Swap (engine, tranny, ecu)
Captain Deeeez Nutzz
...SOLD...
Means on contact: 757.717.2394, PM or this thread
Trades: No thanks
Price: $250
Description:
I have a D15Z1 swap that comes with Vx transmission and P07 ecu. Mileage is around 175K. Engine runs good. I've never used the transmission as I run a cable transmission in my ef right now but was told it shifted fine when I aquired it. Newer water pump and timing belt. Oil pan gasket, rear crank seal were replaced. Motor is still in my car for another week or so if you'd like to come and drive it before I pull it.
I swapped this motor into my daily ef hatch for fuel economy purposes as this motor is rated at 50+ mpg. I'm putting something a little more fun into my car so I no longer have any need for it so if you want a super economical swap for your daily this is it. Also if you need info with swapping into an ef (lot's of fun wiring) let me know as I've swapped the d15z1 motor into 3 of them and also an eg ex.
Trades: No thanks
Price: $250
Description:
