Built Sr20det, Eagle/Wiseco/Cosworth/ARP/Brian Crower/ Head work. Runs Great!!!
Means of contact: PM or call/text 919 995 5453
Price: $1450 picked up
This came out of my s14. I am selling just the long block. This means you get exactly whats in the pics. No manifolds, turbo, coil packs, harness, etc. This is just for the built SR. Here is whats done to the SR...
Parts-
eagle rods
wiseco pistons
cosworth metal HG
arp head studs
Brian Crower spring and retainer kit
P2M rocker arm stoppers.
all new seals and gaskets (front main, rear main, valve stem, etc)
Machine work-
Head was cleaned, pressure tested, resurfaced, and ported
Crack was polished
This motor is SOLID. Throw some cams in it and itll be a monster. It did have 272 cams in it but the Jim wolf ecu was chipped for stock cams so it ran like crap. Thats why the stock cams are in it now.
This engine doesn't leak, tick, knock, smoke, over heat, mix coolant with oil, etc. It runs amazing with ZERO issues. When i drained the radiator it was all green antifreeze and when i drained the pan it was all nice oil with NO metal flakes anywhere. When i bought the car i gave it a compression test and it was 157-158 across all 4 cylinders. Great numbers!
here are pics and vids to prove how nice this motor is. Hope you guys like Yashio Factory pink lol.
Vids
Price- 1450 picked up. That is a steal for this motor. There is more than that just in the parts
May be open to some trades. i guess just offer stuff. i like 240s and guns if that helps narrow some things down.
Parts-
eagle rods
wiseco pistons
cosworth metal HG
arp head studs
Machine work-
Crack was polished
Vids
d16z6crx
Engine / Exhaust / Drivetrain
09-05-2010 05:42 PM
p2r
Part Outs
168
02-17-2010 07:06 PM
((sr)) kelly
03-15-2009 05:30 PM
