Built all motor b20v full swap. 240 hp capable. Top of the line.
Means of contact: 3042401958 (text or call)
Price: $4000 for full swap, 2500 for motor
Description:
Fully port and polish b16 head done by portflow with supertech valvetrain over sized valves, skunk2 pro2 cams,freshly powdercoated valve cover, dsm 450cc injectors, toda adjustable cam gears, golden eagle vtec kit, rs machine pistons 84.5 mm 11.5:1 comp, shotpeened ls rods arp rod bolts acl main and rod bearings, arp head studs. Edelbrock performer x intake manifold, logic motorsports tri y header, competition clutch stage 4 6puck with 7lb fidanza flywheel, b16 trans, swap engineering solid motor mounts, axles, starter, half shaft, and alternator. Everythings new except for the trans.#
Pictures:
ILOVEPENIS -- If this line is still here it means you probably didn't fill out the required information correctly and a mod will be locking your thread shortly. You should probably delete it.
Description:
Pictures:
