BUILT 302, Mustang Performance Parts, CHEAP.....DONT HAVE A MUSTANG ANYMORE
Means of contact: 757-254-5458
Price: $depends
Description: ok so to start off ill say that i havnt messed with a mustang in a long time so i cant remember all the specs exactly but ill post everything the best that i can remember...
First off i have a built 302, Has forged rotating assembly, E-303 cams, double timing chain, hardened push rods, lifters, double springs, edelbrock heads, trickflow upper and lower intake, full msd ignition system, bbk throttle body and mass air flow, comes with tuned computer and made 425 on a 75 shot, engine needs valve covers because i sold them, other than that this is a turn key motor ready to go $2500 OBO
second i have basically a full top end it has ported heads (e7 heads i believe) e-303 cam, ford racing lifters and push rods, comp cams double roller timing chain, an other odds and ends i only want like 325 for all of this
and lastly i have a BNIB mishimoto 3 core aluminum radiator, with the aluminum shroud for 2 12" fans and aluminum radiator mounts, ALL BRAND NEW radiator has never even been out of the box, comes with no question asked warrenty from mishimoto, $300
CONTACT: CALL or TEXT 757-254-5458 Name is seth.
Pictures: TEXT FOR PICS
Price: $depends
Duct tape & Zip Ties
Re: BUILT 302, Mustang Performance Parts, CHEAP.....DONT HAVE A MUSTANG ANYMORE
if your not sure if they are e7 heads here is a picture you can compare with your heads
good price on it all, glws.
If they are gt40 or gt40p heads you have the infamous cast lines on the back of the heads. the codes are also located in the valley of the head by the springs if I remember correctly. been a while since I messed with a mustang.
yes the heads are e7 cast heads, with a mild port job....COMMON PEOPLE THE PRICES ARE GOOD, GET THIS STUFF OUTTA MY GARAGE..
