B20vtec unassembled. w/ many new parts.
True Street
-Alberto
-Winchester
-E-mail@ betopani@ymail.com or pm me
-Not really looking for trades, but feel free to pm me your thoughts
-Asking $2,400 and is somewhat negotiable, feel free to pm me any reasonable offers
-Not parting for now.
-Reason for selling: I moved about a year ago, before I did, economy/bills weren't much for me to worry about, so I spent a good amount of money on cars etc. I will be moving again most likely to an apartment/condo & wont have a garage, so as much as I want to hold on to this stuff and finish what I started, I wont be able to take all this with me or finish it before I move since I have other priorities right now.
***Note: This block is NOT assembled yet. This way you can be sure everything listed here you will get. Also, some ppl, like myself, have better peace of mind if they or want to have someone assemble the engine.
I have a B20B Block which includes the following:
-oil pump, water pump, oil pan, crank, etc.
It does NOT come with stock pistons or rods.
Block will only need to be honed, sleeves are fine.
-BNIB eagle rods
-BNIB ACL race series rod bearings
-Wiseco Pistons: 84mm, 12.0 Comp. no pistong rings
-BNIP Honda head gasket
-BNIP block guard
Complete stock internals GSR head which includes:
-OBD1 Distributor w/ Used NGK plug wires
-Cams w/ Unorthodox cam gears [silver/black]
-Valve cover
-Skunk 2 intake manifold
-STR 68mm T.B. with TPS sensor
-Factory fuel rail
-880 injectors or factory GSR injectors -$100 off the price
-BNIP Honda set of valve seals, intake and exhaust [not installed]
-All sensors that should be on the head.
-S4C Hydro Trans. w/ speed sensor, perfect condition, mileage was @ 7x,xxx & no, I dont have proof, but otherwise I would not had hold on to it for over a year, I bought this trans even before I bought the b20 block, etc.
-GSR shift linkage
-Rear Mount Bracket [EG/DC]
-OBD1 GSR JUN chipped ECU, I love this ECU
-OBD1 Engine harness w/ resistor box for the injectors listed above.
**Updates: Parts that will also be included.
-Set of axels
If asking price is met, I will order a new set of piston rings for the buyer at my expense.
E-mail me for any questions. I will post more pics over the weekend when I get some time to pull the block/trans out the garage at my parents house.
-Winchester
-BNIB eagle rods
-BNIP block guard
-Valve cover
-Factory fuel rail
-GSR shift linkage
-Set of axels
True Street
True Street
