B20 shortblock - GSR shortblock - B16 Head - P75 Head
Means of contact: 703-785-8895
Price: Trade for Skunk2 Pro 2 B Series Cams
Description:
I have 2 shortblocks and 2 heads for trade, looking for a set of skunk2 pro2 B Series cams.
The B20 I was told was running poorly when purchased. Upon removal of the head, I found that it had a broken crank angle sensor (on oil pump) and a damaged valve. Includes oil pump (still installed) and water pump and pipe (removed). The rod/crank bolts have not been separated, oil pan still installed. The P75 Head that I have was removed from this block.
I also have a GSR Shortblock that needs to be rebuilt. The block includes rods, pistons, crank, mains, and girdle.
I have a B16 head, pulled from a running car, no cams, no vc, no im, no dizzy. Includes all cam caps, oil rails, and coolant neck.
Everything has been kept inside, out of the weather.
Pictures: [ATTACH=CONFIG]119309[/ATTACH][ATTACH=CONFIG]119308[/ATTACH]
I'll post pictures of the blocks and the B16 head when I get a chance.
Description:
97 EJ8
Engine / Exhaust / Drivetrain
04-16-2011 04:01 PM
larryluv
04-07-2011 12:22 AM
gsr4door13
12-15-2010 12:00 PM
69vette
05-11-2010 10:30 AM
