b17 gsr motor b16 trans and stuff
Mike
martinsburg wv 25405 About 20 mins from winchester va
pm or email mikeisskyhigh@verizon.net
or call text 240 329 1165
b17 gsr motor b16 trans and lots of stuff
Can list it on ebay for a few buck xtra.
Shipping to canada is gonna be xtra but I will ship to you.
IF YOU USE PAYPAL I ONLY ACCEPT IT IF YOU HAVE A CONFIRMED SHIPPING ADDRESS. THIS IS NON-NEGOTIBLE.
Text me or call me 240-329-1165 for paypal info or message me on the forums.
I AM LOCATED IN MARTINSBRUG WV 25405
usdm b17a1 motor
NOT SHIPPING THIS MOTOR!!!
runs and drives great have a video and compression test to prove it runs great.
Motor does not leak or burn oil, motor has no spun bearings
compression test is semi cold
It it higher but since the motor was not completely warmed up this is what i came up with to show its condition with the motor warm to the touch.
THIS AGAIN IS WITH THE MOTOR WARM TO THE TOUCH, IT WILL BE HIGHER WITH IT FULLY WARMED UP.
cyl #1-220 #2-215 #3-209 #4-214
I am looking for best offer or trades for k series parts, d-series with lots of cash on top etc... or trades for cash only.
Comprssion test warm to the touch
b16/gsr jdm non lsd cable trans
dont need it not sure if its a gsr or b16 but was told its a jdm b16
anywho i dont care what it is i want it gone
Trans does not grind pop out of gear or anything it is truly a good trans
250 picked up no shipping
itr 5th
More pics to prove it came out of a itr trans as i still have the trans
50 shipped?
Good ls rods and pistons out of an obd2 ls motor.
Rods and pistons are in great shape though they are used.
20 shipped for both rods and pistons both, I am not taking the time to seperate, not worth my time
slightly used b series clutch oem replacement. Has more than half of its life left.
40 shipped
b series flywheel used for 10k was a new oem replacement
does not need resurfaced if its used with clutch above
20 shipped
b motor alts 2 obd2
all work and are in great shape
20 shipped each
dc gsr 94-01 mounts not torn or ripped in great shape
also have the rear mount (not picd)
60 shipped for all 3 main mounts
ls crank was out of the same block that the rods and pitons came out of but the timing tensioner bolt broke off thats why I parted it out.
No spun shit no need to resurface it just drop it in check your feeler gauge specs, drop the bearings in and run it.
70 shipped
dx 5spd trans no ginds
80 picked up no shipping
d seires clutch and flywheel
clutch has half life left and flywheel is in good shape minus lite surface rust.
30 shipped for both
*** dizzys for sale
all work and where tested and come with wires cept for the z6 dizzy comes with no wires
*** no pic 0bd2a new gsr vtec dizzy came off a 96
80 shipped and I mean its new still fresh out the box
no pics will post them later
obd1 ls dizzy
newer unit only a year old
60 shipped
dc radiators for b motor comes with all fans
works and does not leak, or worn out haggled hacked shit.
New one has only been used for 6 months then car was ass ended.
I can ship etheir one with the fans or with out fans anywhere pm me.
60 picked up for this one
this one is 20 picked up
***no pic
gsr etc knock sensor in working order parted off a block I sold
45 shipped
*ls tapped oil pan for turbo taped at the top of pan needs to be cleaned out
best offer shipped
usdm b17a1 motor
itr 5th
50 shipped?
40 shipped
20 shipped
b motor alts 2 obd2
20 shipped each
70 shipped
30 shipped for both
*** dizzys for sale
obd1 ls dizzy
60 shipped
***no pic
45 shipped
best offer shipped
Re: b17 gsr motor b16 trans and stuff
I got a price for the block, think he said 1400. For a b17 that is expensive. there isn't much difference between this and a b16. GLWS
