B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)
Old Aug 12, 2016 | 11:23 AM
PWRVTEC's Avatar
Venuto Ottenga Alcun
PWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to beholdPWRVTEC is a splendid one to behold
Post B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)
Means of contact: PM or TxT (7 five 7-3O3-Five888)
Price: $ Various see below and OBO
Description:
2 Sets Valve Springs for B16 (1 set of retainers) (7k Miles), 2nd set (9k miles) $70
OBD2 B16 Injectors with OBD2 Clips 9k Miles $50
B16 Intake Manifold (Throttle body opening ported to 70mm) $40 Pic to follow
B16 Clutch and Flywheel (from 2000 Civic Si) 9k Miles $50
B16 Oil Pump Gear 9k Miles $50 Pic to follow
Stock 2000 Civic Si Fuel Pump 9k Miles $20
Stock 2000 Civic Si P2T ECU 7k Miles (SOLD)
Attached Thumbnails B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)-springs.jpg   B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)-p2t-ecu.jpg   B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)-injectors.jpg   B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)-fuel-pump.jpg   B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)-clutch-flywheel.jpg
Old Aug 15, 2016 | 10:55 AM
PWRVTEC's Avatar
Default Re: B16 Parts from 2000 Si OBD2 (ECU, Clutch+Flywheel, Injectors, Intake Springs etc)
ECU Sold
Old Mar 14, 2017 | 02:22 PM
mellisdb1's Avatar
mellisdb1 is an unknown quantity at this point
Would you happen to have the t bracket from that em1 ?
Description:
ryzach1000
Engine / Exhaust / Drivetrain
Mar 13, 2011 05:18 AM
