b16 obd2 alt, obd2b to obd 1 jumper harness, prosport guages, crank pulley.
Means of contact: pm or text (804-536-3879)
Price: $40-300
Description: First of all I will say do not low ball me! If you do I will not respond!
I have a jumper harness that is obd2b to obd1 ecu $50 bucks
OBD2 b series alt that im selling for 50 bucks, Works fine. $50 bucks (the core charge at advance is 55 so its still a good deal).
Turbo XS dual stage boost controller $100 buck just needs a simple switch [ATTACH=CONFIG]151151[/ATTACH][ATTACH=CONFIG]151152[/ATTACH]
I have a few prosport guages that i would like to keep together
http://prosportgauges.com/premium_se...ng_gauges.aspx
- Wideband($209)
- Boost($82)
- Water temp ($71)
- Oil pressure($104)
- i think the last one is oil temp as well ($71)
Would like $300 obo for all of them and thats a good deal cause before shippping they would cost you $537.
I also have a b16 crank pulley for sale $ 40 bucks
Thermastat housing and water pipe $40 bucks
GM 3 bar map sensor $40
Stock gsr cams $40 bucks
Stock ek stearign wheel with airbag $35
Finally a gsr shaved valve cover with 2 10AN bungs in them for a catch can set up $100
Text for pictures and i will post some in a few min
Thank you
Ryan
804-536-3879
Price: $40-300
- Wideband($209)
- Boost($82)
- Water temp ($71)
Thank you
Ryan
804-536-3879
Re: b16 obd2 alt, obd2b to obd 1 jumper harness, prosport guages, crank pulley.
41 views and nothing.... Bump i know u guys need some parts !!!! Make reasonable offers
