b16 obd 0 head, b18a1 parts, ys-1 trans, lightened flywheel/clutch, integra parts
All parts are located in 22485, King George VA. Located close to MD and Fredericksburg. All parts are best offer. Cash talks. Sorry the pictures are terrible. If you want more pictures, please ask.
b18a1 block with crank, pistons + rod, oil pump, water pump, complete head (minus distributor) and oil pan = $150
b18a1 throttle cable bracket $5
b18a1 throttle body with tps sensor - obd 0 - $15
b18a1 IACV - obd 0 - $15
b18a1 intake manifold sensors/valves - $15 for both
B18a1 Fuel rail and high pressure hose and fuel pressure regulator - $15
b18a1 transmission with speed sensor (vss is cracked at the very top but most of it is there) - The case is in great shape other that one cracked off thread where the clutch cable mounts - ys1 - $150 or make me an offer
Used b18a1 oil pan - minor dents but nothing bad - good threads on the drain plug but no drain plug included - no cracks - $25
Used b18a1 alternator obdo - $25
Used b18a1 starter - $25
Replacement fuel pump for 88-91 civic - less than 1 year old - bought from advanced auto for about $125 (Works fine. This is out of my civic. ) - $25
b18a1 like-new autolite plug wires - $5
90-93 Integra b18a1 exhaust manifold and downpipe - all studs are GOOD! (modified to fit a crx/civic) - $20
b18a1 crank pulley (no chips or cracks) - $25
Brackets/etc $5 or included with anything else purchased
All prices are if the items are picked up in 22485 and are NEGOTIABLE! I can help you load it into your car or truck.
Link to MORE pictures of all parts:
http://s20.beta.photobucket.com/user...nian/library/?
Last edited by Danronian; 02-24-2013 at 04:52 AM. Reason: mounts sold, distributor sold, ecu gone, tps gone
Re: b16 obd 0 head, b18a1 parts, ys-1 trans, lightened flywheel/clutch, integra parts
No trades, sorry.
The seller told me the trans had under 100k and no grinds.
Willing to take Ground Control coilovers for an EF civic as a trade.
I still have it for sale but sorry I'm not willing to drive that far.
