B series standard bore and diameter build parts
Ohhh Snap
Ok well I got tired of waiting for these to come in so I went up the several stores and bought everything to rebuild it to OEM specs.
BRAND NEW NEVER OPENED
ACL main bearings for VTEC bottom end-60.00
ACL rod bearings for VTEC bottom end-50.00
ACL thrush washers for VTEC bottom end-15.00
90.00 if all ACL's are purchased together.
WILL TAKE 75 THIS WEEKEND ONLY FOR ALL BEARINGS,GOING ON EBAY MONDAY
Complete GSR intake manifold gasket kit including plenum gasket etc etc-30.00
Fel Pro 81mm headgasket,intake manifold gasket-40.00
Viton valve stem seals-20.00
I have receipts for everything, no you will not get them because they show my cc info.
The seals and oil pan gasket are not packaged because I was half way tempted to take my motor back apart and re-build it when everything came in.
va beach
va beach
Ohhh Snap
Re: B series standard bore and diameter build parts
only have the headgasket,valve seals,intake manifold (1 for gsr,1 for b16/type r) headgasket and cam seals.
