b series parts and side winder manifold
Means of contact: 571 208 4586
Price: $obo
Description:
a side winder b series t3/t4 turbo manifold with 38mm wastegate flange 140 obo
garrett dsm turbo oil and coolant cooled in good working condition has stock waste gate 65 obo
air research dsm turbo oil and coolant cooled in good working order has stock waste gate 65 obo
b20 ingnition coil 30 obo
b16 ignition coil 30 obo
3 b series oil pans not tapped 35 each obo
obd2 o2 sensor works great 30 obo
b18b1 crank no scars 50 obo
2 sets of ls pistons on rods one set has bad pistons good rods the other set is perfect both are used 45 obo for the set
b18b1 block bare with windage tray and oil pick up tube needs bore *has scaring* 55 obo good for project or oversized pistons
set of grey gsr leather seats one rip on part where you sit along the seem not on the side 60 firm
carbon creations carbon fiber hood 150 obo
both fenders 45 obo each
2 t3/t4 turbos need rebuilds one has slight in and out shaft play and leaks oil from cold side not hot side good fins still still spools fine the other is destroyed on cold side no smoke or oil leaks at all 50 for both good for parts or fix the one thats still usable [ATTACH=CONFIG]138807[/ATTACH][ATTACH=CONFIG]138806[/ATTACH][ATTACH=CONFIG]138805[/ATTACH][ATTACH=CONFIG]138804[/ATTACH][ATTACH=CONFIG]138803[/ATTACH][ATTACH=CONFIG]138798[/ATTACH][ATTACH=CONFIG]138799[/ATTACH][ATTACH=CONFIG]138800[/ATTACH][ATTACH=CONFIG]138801[/ATTACH][ATTACH=CONFIG]138802[/ATTACH]
trades im looking for
stage 4 or higher clutch complete in new or nearly new condition
lower control arms for ek
rear subframe for ek
rear disk conversion
camber kits
lowering top hats for ek
test pipe
ek coupe exhaust
mounts for b series into ek must be racing mounts i have stock si mounts already and dont need them
99-00 civic front end*hood bumper and fenders* already have the lights
99-00 fog lights for ek with yellow lens
v band downpipe for ek
half sized racing radiator with thin fan
oil catch can must be a nice one not a 10dollar ebay one
Price: $obo
Description:
camber kits
test pipe
ek coupe exhaust
b20vtecturboek
Engine / Exhaust / Drivetrain
03-07-2012 07:43 PM
