Aeromotive Fuel pressure Regulator
Im looking for the A1000 regulator...part numbers 13101 or 13109... mainly used but lets see what you got.
http://aeromotiveinc.com/products-pa...ass-regulator/ http://aeromotiveinc.com/products-pa...ass-regulator/ I can pay for shipping or some gas money so you can deliver. Chucky nova/manassas via Pm (and to the dumb kid who thinks he knows his shit....not any regulator will work. Go on there site and do some research and learn something Newbie) |
Re: Aeromotive Fuel pressure Regulator
13115 - Honda/Acura Billet Adjustable Regulator On product category EFI Regulators
Billet adjustable regulators specifically designed for Honda and Acura engines to provide fully adjustable base fuel pressure. These egulators are direct bolt-on for engines with the factory fuel rail or aftermarket fuel rails designed with mounting provisions for the stock regulator. • Adjustable from 30-70 PSI. The other one you are talking about only goes to 60 psi base pressure:D • Connects directly to the stock fuel rail and return line. • Perfect for use with the factory fuel pump, yet flows enough for larger pumps like the Aeromotive A1000. - see my non native friend if you do soenm research it makes you look dumb doesnt it:D • The same unrivaled, Aeromotive fuel pressure control preferred by the top racers and tuners, in a Honda specific, bolt-on package. • Fuel pressure rises on a 1:1 ratio when referencing boost. • 1/8” NPT gauge port. but you said u needed a a1000 fpr when you are running a a1000 fuel pump wich that fpr will work with but its all up to you |
Dude, I even spoke with Aeromotive because I was thinking about getting your regulator...you can call them if you want they do not at all recommend that at all...Ghetto
