2g Parts, Stock Parts, aftermarket..etc.
-7-bolt water/oil filter housing
-7-bolt crank, needs polishing, 100 miles since microbuff and polish
-Lexus SCX00 HID wiring setup with matsushitsa ballasts, ignitors and D2S bulbs
-2g A/C compressor, good!
-Eclipse CD3000 unit, real nice, CDMP3/WMA.
-Stock 1g Cams
-4 stock cam gears
-Bare 6-bolt head, cleaned up (machine shop bathed)
-Rear VIPgarageonline.com drilled rotors and Axxis MetalMasters Pads, over 60% life left
-Eclipse Passenger Side Racing Seat Bracket
- 7-bolt rods and pistons 73k miles
-Apexi Dunk Muffler
-2g Intake Manifold with EGR blockoff
-1g Lower Thermostat Housing
-SBR3500 Clutch and Pressure Plate, used for 6k miles (no drag duty, a daily)
-1g Balance Shafts
Pictures are all available here:
http://s393.photobucket.com/albums/pp20/Fitzpadj/
-Stock 1g Cams
-4 stock cam gears
-Apexi Dunk Muffler
-1g Balance Shafts
Re: 2g Parts, Stock Parts, aftermarket..etc.
You wouldn't happen to have the stock upper inner cooling pipe. The flexible one that's connected to the throttle body and runs down to the hard pipe with bov.
