1jz disassemble engine $800 obo
Means of contact: pm or txt 804-539-3939
Price: $800 obo
Description: I have a 1jz non vvti rear sump out of a soarer. It's been disassembled block cleaned, honed, and the top deck is flush. Piston and crank cleaned also. I have not messed with the head yet. Will come with almost everything you need to put it back together. No engine wiring harness but have ecu.
Will include extra parts with the motor. These are brand new parts.
water pump, radiator hoses, arp head studs, timing belt, pulley belts, injector "O" rings, valve cover gasket, turbo manifold gasket, thermostat w/ gasket, front main seal, crank seal, intake/ exhaust valve stem seals, cam seals, power steering pump, head gasket, intake manifold thermo gasket, Piston rings n wrist pin bushings, arp rod bolts.
Pictures:
couple of pics i have right now
Price: $800 obo
Pictures:
