1988 Beach Bronco
Old Mar 19, 2017 | 02:57 PM
cstout7's Avatar
cstout7 has disabled reputation
Default 1988 Beach Bronco
Means of contact: 7577713925 prefer text
Price: $6200
Description:
I have for sale or trade my 1988 Ford Bronco XLT. 11/17 INSPECTION. with a 4" suspension lift and 3" body lift, 35" BFG all terrain tires less than a year old, C6 transmission with shift kit, and a fuel injected 351 Windsor installed a year ago with less than 30k miles as of now! miles going up as it is my daily driver. For those Bronco enthusiasts out there, this Bronco is the same one from fullsizebronco.com "Saltlife's Beach Build". He owned the truck two years before i bought it and you can see in his thread that he gave this truck alot of love, i kept that going by finishing his project and making it the perfect beach truck with an engine that will always get you there and back.
heres his thread and below are current pictures as well as what i have done since ive owned it.
http://www.fullsizebronco.com/forum/...ach-build.html
new within the last year:
-new front driveshaft
-new rear driveshaft
-new rear axles
-ball joints
-brakes all around
-brakes lines all around
-brakes master cylinder
-starter
-wheel bearings
-fuel filter
-fuel pump
-transmission seal
-torque converter
-new borgeson heavy duty steering shaft and drag link
Motor:
351 Windsor
Apples machine shop gave the engine a bath, honed the cylinder walls and mating surfaces, installed new freeze plugs, cam bearings, and rod and main bearings as well as new piston rings and polished the crank.
From there the build included the following:
-all new gaskets and seals
-new oil pump
-new water pump
-new valve seals and valve cleaning and polished
-new valve covers
-all new sensors
-new summit racing engine block plate
-new flywheel/flexplate
-new fuel injectors
-new comp cams timing gears and double roller chain
-mild camshaft
-new thermostat
-new Ford racing spark plug wires
-new MSD Distributor
-new MSD ignition coil
-new spark plugs
-new radiator hoses
-new serpentine belt
-heat wrapped headers
-new vacuum lines
I'm sure I'm forgetting a few things but you get it. this truck has been given some serious love and so I need it to go to a good home that will appreciate the work that was put into it and enjoy it! This thing is meant for adventures not to sit and rot in someones yard. As far as trades, I am looking for a toyota 4 runner but let me know what youve got and worst i can say is no! $6200 cash priced to sell.
Pictures:
[ATTACH=CONFIG]188250[/ATTACH][ATTACH=CONFIG]188249[/ATTACH][ATTACH=CONFIG]188248[/ATTACH][ATTACH=CONFIG]188251[/ATTACH][ATTACH=CONFIG]188252[/ATTACH]
Attached Thumbnails 1988 Beach Bronco-img_20160910_180924566.jpg   1988 Beach Bronco-img_20161118_140948632.jpg   1988 Beach Bronco-img_20170319_153506.jpg   1988 Beach Bronco-img_20170319_153521.jpg   1988 Beach Bronco-img_20161027_171146208.jpg
Old May 2, 2017 | 07:26 PM
jmm90's Avatar
jmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these partsjmm90 is infamous around these parts
Default Re: 1988 Custom Lifted Beach Bronco
Hi,
Is your Bronco still for sale? I've followed this thread for years so I am very interested. Please let me know if it is still for sale and we can talk further.
Thank you.
Old May 4, 2017 | 02:22 AM
NasTHatch's Avatar
RIP DRAGVA-2016
Originally Posted by jmm90
Hi,
Thank you.
You sound like the typical Craigslist scammer. You need to reply with a non scammer response or I'm booting you
Everett654
Domestic
Sep 14, 2009 04:42 PM
Everett654
Domestic
Aug 29, 2009 05:59 PM
