what PSI do ya'll run
Old Mar 27, 2007 | 10:24 AM
WutupYo's Avatar
GLHF
WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo WutupYo
Default what PSI do ya'll run
just curious, i just went to 35 in the rear and 30 up front. they were both 5 PSI lower
Old Mar 27, 2007 | 10:31 AM
JStab's Avatar
Its Lightish Red
JStab JStab JStab JStab JStab JStab JStab JStab JStab JStab JStab
Default Re: what PSI do ya'll run
45psi FTW
Old Mar 27, 2007 | 11:01 AM
Chino's Avatar
Your Kneegrow
Chino has disabled reputation
depends if i'm riding 2 up or not...if i'm by myself then whatever's in the manual.
Old Mar 27, 2007 | 11:13 AM
snikwad's Avatar
1 happy dude
snikwad snikwad snikwad snikwad snikwad snikwad snikwad snikwad snikwad snikwad snikwad
whats better, going with whats on the tire or whats in the bike manual.
I mean th emanual is written for OE tires and 2 up.
i ride solo and definately not on OE rubber, so which should i go off?
Old Mar 27, 2007 | 12:34 PM
Del La Sol 1320's Avatar
Del La Sol 1320 has disabled reputation
i would say its best to go with the tire's recommendations as that varies much more than the make of bike does, but alot of the times it seems to me the number on the sidewall is kind of high. I guess they err in the high side, because the same tire could be on a 360 lbs 600 with a 125 lbs rider or a 500 lbs busa with a 250 lbs rider, so they don't know what its going to be supporting.
I would say the average is low 30's for most tires, but some things, like my mich power races have wierd pressures, 32F/24R.
Some of the tire company's websites have lists that have recommended pressures according to your bike, if that fails then just call them up, they should be able to tell you or can direct you to someone there who can.
Most imporant, what bike, tire, and size are we talking about?
Old Mar 27, 2007 | 12:50 PM
Armenian's Avatar
CLUTCH IT UP
Armenian has disabled reputation
23-28 perfect for circle wheelies
I run 25-28 on my supermoto. Any higher and it'll highside/lowside too easy (no cush drive or slipper clutch).
Old Mar 27, 2007 | 01:34 PM
WutupYo's Avatar
GLHF
i've got an 04 636 with bridgestone battleaxes on it right now, 120/65 up front and 180/55 in the rear. they will soon be replaced with some pilot powers more than likely, or metzler M3's if i can
Old Mar 27, 2007 | 01:41 PM
CarsRFun's Avatar
Im here for the beer
CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun CarsRFun
0..................
Old Mar 27, 2007 | 01:57 PM
oddball's Avatar
oddball has disabled reputation
45 no matter if one person or two always
Old Mar 27, 2007 | 04:08 PM
WutupYo's Avatar
GLHF
45 just seems like a lot to me, maybe i'm just over thinking it
