NEED import bike motor help slash mechanic
I Love to Hate
I am looking for someone to look over this motor i just picked up and let me know what i need to get it back up and running. going on a crazy project.
anyway the motor is a ~'78 honda CB450. All parts are here, trans shifts great and head is clean but the head is off and there is surface rust on pistons and such. No carbs on it. Im really wanting to get an estimate on what it will take to get it back up or if i should just get another motor to start with.
Thanks
Thanks
Re: NEED import bike motor help slash mechanic
what are you looking to do?. just try and reinstall the head(top end kit) or full out oem rebuild or "going crazy" cams, new valves, valve job, under cut trans, over bore pistons, rods?..
i mean really if your just trying to get what you have up and running then probly gonna be around $500. but if you wanna start upgrading its going to be $3000+(pistons $600+, cams$500+, undercut trans$750-1000)
cb carbs are going up in price as well as any older bike(kz and cb being the most pricey). might be worth it to just get some flat sides or converting to a newer style carb. i dont really know what your doing but you could do some crazy carb set up.
I Love to Hate
i guess what i need is to have the cylinders inspected and reassembled back to running order.
What is involved in this modern carb swap or "flat sides"
im simply looking to get it running reliably for the least possible. found a few sets of carbs on ebay but im sure they will need rebuilt.
as far as carbs, alot of carbs off different bikes will bolt right up with a carb boot swap(i dont know off my head what bike). then its just down to needle height and jeting. flat slides are pricely as hell(like $800-1500) they should have a bolt on kit
my house is a good little haul from va beach. its about 150miles round trip. but pm me you number and i can text you. i probly can take a ride over on my bike or something this weekend. i dont really get on this forum much anymore
