NEED HELP ASAP (CLUTCH)
Old 09-02-2009, 04:01 PM
PAWESOME's Avatar
PAWESOME has disabled reputation
Exclamation NEED HELP ASAP (CLUTCH)
Bike: 1989 Ninja zx1000
I just got in my new clutch (fibers & steels)
I went to install them and I did everything to the T like I always have with any of my bikes.
EXCEPT
My Uncle decided to pressurize the clutch lines while the basket or anything was connected...
Now the piston that pushes the basket outward to release the clutches is stuck and i cannot complete assembly of the clutch
I bled all the fluid out the system and the piston still won't retract, it's stuck in the position as if the clutch was disengaged.
If anyone can help via phone or stop by... please call immediately for more information
Will pay for answers/help.
Thanks
757 927 9639 (Portsmouth/Chesapeake)
PAWESOME is offline
Old 09-03-2009, 11:49 AM
PAWESOME's Avatar
Default Re: NEED HELP ASAP (CLUTCH)
I took the slave cylinder off and pulled the connecting rod out so now the clutch is installed etc... but now the clutch won't bleed...
PAWESOME is offline
Old 09-03-2009, 03:39 PM
yes sir
rollingstock's Avatar
rollingstock has disabled reputation
geeezz. sounds like u got air in the lines.. but u did alot of work for a easy job..
sorry.. cant really help u without seeing the bike. since i really dont know what all u have done
rollingstock is offline
Old 09-04-2009, 08:32 AM
EMCracing's Avatar
EMCracing will become famous soon enough
hay its shane i can fix it hit me up if you want
EMCracing is offline
Old 09-24-2009, 09:04 PM
PAWESOME's Avatar
Thanks shane. I got it to bleed but now when on interstate and it gets hot the slave likes to stick out 1/8 to 3/16 inches causing my shit to slip. WTF
PAWESOME is offline
2-D
01-16-2009 11:59 AM
DAinteg91
01-28-2008 01:07 PM
Quick Reply: NEED HELP ASAP (CLUTCH)
