first run with the new rubber
Old Feb 10, 2009 | 06:55 PM
crxnfx's Avatar
I have a 20 valve...
Default first run with the new rubber
ok, so I took into consideration all that you guys preached. in order to put miles on the tires, you actually need to put miles on the tires.
I drove to work this morning (fucking shit it was 41 degrees) and the tires were cold and felt....greasy. thats the only explanation I can give. It feels greasy. Not oily- slippery. Greasy.
After work I went to my favorite haunt and spent about 45 minutes each, taking the roads at about 30%. I was driving about 15mph under what I normally do and each time I could feel the bike slipping a little for each turn. A little lower, a little slip.
But then the next turn with the same angle, it was fine. Its going to be scary as shit for the deep fast turns though. Or switch backs.
As always, I will continue to be careful.
Also, even though it was the exact same tire as last time, its like fucking your girlfriends twin sister- she may look the same, but she don't act the same.
tires are already reacting differently, even better, and they aren't even broken in all the way!
and I ran out of gas again but a border patrol agent came by and filled my tank....for a blow job.
Old Feb 10, 2009 | 07:10 PM
Real Random's Avatar
Default Re: first run with the new rubber
so?
Old Feb 10, 2009 | 09:00 PM
MA-HALF-E's Avatar
Awesome.
Stop being a dick.
Old Feb 10, 2009 | 09:08 PM
idkmybffEM1ly's Avatar
uhh.. what?
idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly idkmybffEM1ly
Old Feb 10, 2009 | 11:30 PM
sprayedcivic's Avatar
On One Wheel
sprayedcivic has disabled reputation
scrup ires down with sand paper and some paint thinner to get the release agent off then clean tires it did so to a shinko i was running and ran it at deals gap
Old Feb 11, 2009 | 05:26 AM
djgrom's Avatar
LaShawn
That is also sketchy as shit.
Yeah they will feel greasy not oily. You get that same greasy feeling also when you overheat your tires racing.
Old Feb 11, 2009 | 05:36 AM
crxnfx's Avatar
thanks for the tip, but if you don't mind, I'll break them in the normal way.
Old Feb 12, 2009 | 04:15 PM
crxnfx's Avatar
tires are officially broken in.
ShawnD
Aug 6, 2008 05:25 PM
RHDSIR
Nov 24, 2005 02:34 PM
