06 gsxr rear tire..fit a 200??
Old May 27, 2008 | 06:30 AM
durang-low's Avatar
go fast or move
durang-low has disabled reputation
Default 06 gsxr rear tire..fit a 200??
trying to find out if i can put a 200 series tire on my 06 gixxer 750...got pilots on it now 180 but would like a 200..anyone know??
Old May 27, 2008 | 06:39 AM
EH3_SOHC's Avatar
for alarms/rmt-strts
EH3_SOHC has disabled reputation
Default Re: 06 gsxr rear tire..fit a 200??
only supposed to go up one size
Old May 27, 2008 | 06:40 AM
Real Random's Avatar
try a gixxer forum
OR look in the manual for your bike, it should tell you what sizes can fit
Old May 27, 2008 | 03:51 PM
SeanJohn's Avatar
SeanJohn has disabled reputation
I say keep the 180, the bike will handle better and you'll have more traction because the 180 will curve correctly as opposed to the 200 which is pinched and thus has less contact surface.
Correct me if im wrong.
Old May 27, 2008 | 03:56 PM
Voodoo ST's Avatar
Handling is Key!
Voodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these partsVoodoo ST is infamous around these parts
Youre right sir........
Old May 27, 2008 | 04:50 PM
look at SJ!
all edjumacated
Old May 27, 2008 | 05:01 PM
ScrewD03's Avatar
Slowest 240 EVER
ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03 ScrewD03
I say stick with 180...
Old May 27, 2008 | 06:56 PM
skr00zloose's Avatar
hatrs make me famous
a 200 will fit but is pointless. a 180 and a 200 on the same sized rim isn't any wider, and the 200 will handle like crap on the stock rim. if you're just trying to make it wider in the rear, you need a wider rim for that 200.
a 200 on a stock rim will not want to turn in, and once you get past the squared edge of the tire you created by putting that tire on that rim, it'll fall, quickly, into the corners, with a small contact point, and you'll end up on your butt if you push it.
Old May 30, 2008 | 07:17 AM
durang-low's Avatar
go fast or move
thanks for the info.. think i'll stick with the 180 pilot i got then..
Old May 30, 2008 | 11:52 AM
tenacious's Avatar
tenacious has disabled reputation
i agree
TheGreatLean
Feb 17, 2009 12:57 PM
dowhatiwant
Aug 7, 2008 06:17 AM
98civicONair
Want to Buy / Trade ARCHIVE
Dec 5, 2007 01:34 PM
