06 gsxr 600 clutch problem
i have a 2006 gsxr 600 when i pull the clutch lever in the bike still wants to creep a little i have adjusted the cable as much as possible and that didnt work. Does anyone else have a suggestion on what it could be?
hatrs make me famous
Re: 06 gsxr 600 clutch problem
nope, there's two adjustments. the fine adjustment is at the lever, the course adjustment is at the pushrod. It shouldn't pull in gear with the clutch pulled in. maybe on a harley, but not on a jap (superior) bike.
if you want the adjustment procedure from top to bottom, let me know. I think I posted it here a couple of times, if not, I'll type it all out.
it still shouldn't "pull" in gear with the clutch in.
look at your front sprocket cover, or nearby, is there a plastic/rubber plug in the middle of it?
I'm not 100% sure if the '06 is on the left like the older GSXR's or the right like alot of other bikes.
better yet, follow the clutch cable down till it goes into the motor, tell me which side it's on, and I can give you a step by step.
on the left side, pull the clutch and u can see the part move, u can adjust it at the end of the cable, however, if it is creeping up a little than you should be able to adjust it at the lever.
seen this with 3 diff 06-07 gsxr 600, 750 from 3 diff dealership.
the 4 things the dealers missed were the chain slack, throttle slack, clutch slack, and tire pressure adustments. dealer prep cost my ass
