V8 help. LM7 vs. LQ4 vs. LS1!!!
#31
Re: V8 help. LM7 vs. LQ4 vs. LS1!!!
Im planning to switch over to one of these engines in my 240 drift car. Boost is really not an issue but I can toy with the idea. I would like to run a nice v8 with basic mods to yeild 400hp. The LS1 would be ideal, but the Lq4 sound like a nice budget build with similar results. Weight doesnt really matter. My car weights around 2300lbs with the SR right now. I can live with another 100lbs if it means it will save me thousands of dollards. These engine seem to be priced really good compared to the LSjuan. I would love to get a hold of an ls2, but they are out of my budget. The ls1's i have found are either too expensive of have damage to them.
stay with a stupid japanese motoer in your japanese car dont bring in the gm motors for the garbage. why not a skyline motor dont go gm they are to good for a 240sx
#32
Cool story Hansel.
#33
#34
Ed is highly spoke about around here!
Also, BlackBear Performance in Alexandria can tune them for cheap, he is used alot over at gmfullsize.com on the trucks. LSxtune in Richmond as well.
#35
Danny@respecgarage
I appreciate all the info. right now Im in the searching/learning mode. I have a lot to learn on these engines and hopefully I can get something to start tinkering over this winter.
#36
Danny@respecgarage
So this happend during the weekend.
98 camaro LS1
I will be sending it to abacus to get the block honed and cleaned.
98 camaro LS1
#37
I fully understand your point and agree with it. Im just trying to keep my options open. An LS1 is already adding about 50lbs to the front suspension. Adding another 100 on top of that 50 will change the handling of the car. I am looking for an ls1 atm. well see what i find. I always seem to find good deals.
I personally run an LQ4/T56 in my S14... Even with the Iron block it weighed 31 pounds LESS than the KA fully dressed. Which I literally could not believe my eyes when I sat it on the scale. I know SR's are lighter but in my case it still weighed less after the swap then what I started with. As for the 5.3/6.0 decision, its really a no brainer to go with the 6.0... Its the same block dimensionally so it weighs less because it has less material and they can be had for almost the same price (LQ4 versions anyway). Also the Iron block is ~65 pounds heavier than the aluminum LSX variations. As for the newer aluminum 5.3's, they come with a pretty premium price but they also come with better heads/intake than LS1's. Really when you go LS1 youre paying a premium on name alone unless you find someone that doesnt know what they have. Price to performance ratio weight or not heavily favors the truck engines. They do require some extra parts and ALOT more wiring however.... I converted to a 00 F-body harness which made life a million times easier. Also tuning is the same because I run LS1 PCM.
Apart from some extra legwork I figure I saved easily a thousand dollars going iron.
#38
Danny@respecgarage
That's what I foound when I was doing a little research. The LQ4 engine is a very good alternative to the over priced LS1. In my case, Im embarrased to say this but I have spent less than a thousand on a full ls1 swap and a busted t56. So in my case Im lucky. I might just find an LQ4 to throw in my silvia-rado missile drift car.
69vette
Engine / Exhaust / Drivetrain
05-18-2009 03:09 PM
