Giggle Gas
Re: Giggle Gas
Had a friend who offered me a deal that seemed to good to pass up so now I own a N20 system for the Vette. Anyone have experience with this stuff on a LS1? Was just gonna use it for passes at VMP/MIR. I just put a tune on the car to get rid of all the KR, should I have it retuned for use with the system?. Whats a 'reasonable' shot for this stuff? (on generally a stock engine) I'm researching like fuck before I spray so any input would be appreciated
What I have includes the following;
10lb bottle
Different size nozzles - 35 shot to 200shot.
2 accessory ports, 1 safety release burst port
purge solenoid
tubing
blow down tube
fuel supply pressure safety switch
mechanical pressure gauge
bottle mount/heater
2 stage progressive controller
remote bottle opener
Already planning on new injectors (which would dictate a new tune anyway) and new plugs. Anything else?
10lb bottle
purge solenoid
tubing
blow down tube
bottle mount/heater
Do not follow the advice of placing 100 or 125 shot right away. Always start with a small shot and see how the car reacts.
Last that fuel pressure safety switch is probably useless, they are not calibrated to the fuel pressure of an LS1 fuel rail. By the time it senses a fuel pressure dip your #7 and #8 cylinder will have already detonated. Get a fuel pressure gauge mounted inside the car using an electrical feed.
Re: Giggle Gas
bottles are for babies..
whats the point? u have a LS1, that already has loads of tremendous potential..
plus ur car using dinitrogen monoxide is like dipping ur motor in acid.
Troll & Run
Fidel runs VBPD
Re: Giggle Gas
With dinitrogen monoxide or nitrous oxide or nitrous (whatever u wanna call it) it is a very risky mod. One ignored error while setting it up can potenially melt your motor (small fuel pump w/ N2O = melted engine). Im not saying adding N2O is retarded, but if you are going to add N2O your eventually gonna have to add better internals (forged pistons, stronger connecting rods and bearings...). Soo why dont you just invest it into something worth while like those cams and springs for your LS1 ehh?
cams and springs guy:
http://www.ls1tech.com/forums/dynamo...-mild-cam.html
Re: Giggle Gas
You assume that other mods do not come with risk, like installing a cam and springs for example. In order for you to do this you must pull the balancer and front engine cover off, there is risk in that alone, many have broken balancer bolts off in the crank snout. The risk of introducing debris into the engine during the process or water intrusion exist. The camshaft itself if not checked may actually be longer duration or higher lift than what was ordered and well when Mr Valve meets Mr Piston it is not going to be pleasant. It happens quite often and further the additional RPM that can be achieved with a different camshaft and specifically the year of LS1 this person has can stretch rod bolts.
That is just some of the risks with that mod, but you also assume that N2O is dangerous or much more risky when in fact it is actually less risky when installed correctly with the right equipment in place. The stock fuel system is safe to a 150rwhp wet shot. The removal of 2 degrees of timing ensure a safe buffer along with the cooler spark plugs. The RPM switch prevents potential problem by cutting the system above specified point. The N2O is not constantly on and is only used when needed, so it is not stressing the motor like a cam and heads do constantly. It needs no other supporting mods to get the maximum gain.
I seriously doubt someone got 71 rwhp out of just a cam install on a completely stock LS1. Average gains are 25rwhp with near 40rwhp on the high side without headers and 10-15 additional with. You would need a set of heads and an aftermarket intake in place to achieve 70rwhp with just a camshaft.
edit: Your observation skills are lacking, I read your link. He installed LS6 heads and an LS6 style intake manifold, further Patrick G can spec a camshaft like no other, but take any dyno with a grain of salt. Further they used stock exhaust manifolds which is not the same as stock exhaust, this is a custom roadster they installed in which the stock manifolds are like shorty headers.
You assume the stock internals are not strong enough to handle the N2O, yet you believe they are strong enough to handle a camshaft install and further modifications without a need for additional strength. I doubt you know much about anything in an LS1 if you believe there is a difference. More people destroy motors with internal modifications than with N2O when the system is set up properly.
Re: Giggle Gas
Ultimately, the car will be going LT's, 3.90 quaife, LS6 heads, LS6 intake, and a G5X3 cam with roller rockers. I think that should give me 400hp that will pull. After all that, I'll be doing some HPDE's
