Check Engine Light Help Needed. 96 Integra
Old 10-20-2010, 12:58 PM
ls96swap's Avatar
ls96swap has disabled reputation
Default Check Engine Light Help Needed. 96 Integra
So Im trying to check my cell codes and I jumped the blue connector. But the only thing flashing is the abs light. How do I get it to check the check engine light?
ls96swap is offline
Old 10-20-2010, 01:04 PM
Hi
Integra2Be's Avatar
Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be Integra2Be
Default Re: Check Engine Light Help Needed. 96 Integra
take it to Advanced or auto zone. Theyll check it for free.
Integra2Be is offline
Old 10-20-2010, 01:09 PM
ls96swap's Avatar
I know how to check it but how to switch it from abs codes to cel codes. I dont know how to do. and it dont drive right now so I couldnt do that even if I wanted too.
ls96swap is offline
Old 10-20-2010, 01:21 PM
I think you can rent OBD2 scanners also. For the ABS I think I remember that there is a way to jumper the diagnostic connector and the ABS MIL will flash out the ABS codes.
Google something like "OBD2 Honda ABS codes" and see what you come up with.
Old 10-20-2010, 02:26 PM
ls96swap's Avatar
I have a obd2 scanner but it doesnt work I guess becuase I have P28. But does anyone know how to switch from checking the abs codes to cel codes?
ls96swap is offline
Old 10-20-2010, 02:32 PM
So which one do you want to check, CEL or ABS codes? If you have a P28, you can't use an OBD2 scanner because OBD1 ECUs don't use the OBD2 protocol obviously. You can jumper the service check connector by the glove box and the MIL should flash out the codes.
Old 10-20-2010, 02:41 PM
ls96swap's Avatar
Ya I know that, but when I got to jump it only the abs light flashes, when I know I should have cel flashing too.
ls96swap is offline
Old 10-20-2010, 03:11 PM
So you're not seeing a CEL, but know you should have one? Do you see a continuous CEL under normal conditions (connector not jumpered)...?
If you're not seeing a CEL in normal operation, it would be natural to assume that you would not see a flashing CEL when you jumpered the diagnostic connector.
So this tells me one of two things:
  1. You don't have a CEL, but you have an ABS problem
  2. The CEL is blown or not connected properly
kevy wevy
04-16-2009 08:03 AM
fxrolla
03-24-2007 07:19 PM
marshallbc
11-15-2005 05:48 PM
crazyb
08-30-2005 07:53 AM
snozepp147
09-10-2004 04:21 PM
Quick Reply: Check Engine Light Help Needed. 96 Integra
