Car Parts
Old 12-21-2004, 02:34 PM
1999 Eclipse GS-T
gstrbo99's Avatar
gstrbo99 has disabled reputation
Default Car Parts
Looking for a junk yard to find a mustang for donor parts. If any one knows of any please help me out. Or if you have a 5.0 manual beater that I can take off ur hands cheap lemme know. Has to be between 87-95. Thanks
gstrbo99 is offline
Old 12-21-2004, 03:25 PM
Shadow's Avatar
Shadow has disabled reputation
Default Re: Car Parts
Johnson's Mustang and truck parts 4513 bainbridge blvd Chesapeake
545-8370. Cars are picked over pretty good and prices are a bit high.
Shadow is offline
Old 12-21-2004, 03:53 PM
The Pro to call.
HatefulMechanic's Avatar
you are wanting an engine/tranny/ECU i assume? cause the fox chassis ended in 93. good luck finding one, most every wrecking yard is cleaned out of them, and if they got one, its pretty worn and high priced.
not to mention the 87-88 cars are speed density.....not MAF
try www.corral.net
HatefulMechanic is offline
Old 12-21-2004, 03:58 PM
1999 Eclipse GS-T
gstrbo99's Avatar
actually i already have an engine but i do need the tranny and ECU. Actually i need a manual T-5, steering column and box, speedometer cables, brake cables, drive shaft, rear axl, brakes w/ master cylinder, ebrake handle, and pedal box, ECU, front wheel spindles and lower control arms, radiator and cooling fan w/ shroud, fuel tank, cap and fuel filter, gauge cluster, computer and wire harness, 8.8" rear end assembly w/ quadrashocks, springs, and control arms
gstrbo99 is offline
Old 12-21-2004, 04:10 PM
The Pro to call.
most of the things you list will need to come from a fox chassis (79-93) not an SN95. the SN95 is five lug (unless you are converting, then it will work) and if i recall, the pedal setup is different, as are the gauge cluster/speedo (fox used cable speedo, the SN95 uses a VSS) radiator may work...the SN95's are electric fan vs. the fox manual fan.
brake lines are different, MC is different, as is the rear end too (i havent seen a SN95 with drum brakes, and i dont think the fox was offered with disc rear brakes other then the cobra)
LCA's should work for the rear, but i am not sure if the torque box mounts are the same or not.
fuel tanks i am not exactly sure on, but i have a different part number for the tank on an SN95 vs a fox.
engine harness is the same, but i THINK there is a slight difference in the car harness.
parking brake lever is different too.
hope this helps.
Old 12-21-2004, 04:21 PM
1999 Eclipse GS-T
gstrbo99's Avatar
haha no idea what you jsut said. All i know is that factory five listed the donor parts as the parts necessary from an 87-95 mustang
gstrbo99 is offline
Old 12-21-2004, 04:29 PM
The Pro to call.
building a kit car i see......
i think their reccomendations are incorrect, but they may work. dont see how.....but they make the car...not me. i just work on them
Old 12-21-2004, 04:39 PM
1999 Eclipse GS-T
gstrbo99's Avatar
yea i have no idea im new to everything thats just what they said so thats what im doing
The parts listed below are what you will need to take from the 1987-2004 Mustang. The assembly manual includes this list broken down to the nut and bolt level.
1. Engine and transmission assemblies.
2. Driveshaft.
3. Ford 8.8” rear end assembly w/quadshocks, springs and control arms.
4. Mustang front and rear brake assemblies, w/master cylinder, emergency brake handle and pedal box.
5. Mustang front wheel spindles and lower control arm.
6. Mustang radiator and cooling fan shroud.
7. Ford fuel tank, cap, and fuel filter.
8. Mustang steering rack (w/factory ignition for 87-95 cars).
9. Mustang gauge cluster, computer and wire harness for EFI cars.
10. Mustang aluminum wheels (or use aftermarket/vintage wheels).
gstrbo99 is offline
Old 12-21-2004, 05:29 PM
Shadow's Avatar
If you try to pull these parts from a bone yard it's going to be very expensive and even more frustrating. Most of the parts you listed are in demand so the yards pull them as soon as the car hits the lot. You would be much better off finding a complete car.
Shadow is offline
Old 12-22-2004, 08:44 AM
1999 Eclipse GS-T
gstrbo99's Avatar
aight thanks for the advice
gstrbo99 is offline
Fl1pSde 101
Want to Buy / Trade ARCHIVE
08-07-2008 06:57 PM
Fl1pSde 101
Other ARCHIVE
32
06-18-2008 07:21 AM
Fl1pSde 101
06-05-2008 07:10 PM
Quick Reply: Car Parts
