what would i need to swap b18 into 97 civic coupe?
Old 03-30-2009, 11:41 PM
radiaki11's Avatar
radiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond reputeradiaki11 has a reputation beyond repute
Default Re: what would i need to swap b18 into 97 civic coupe?
96-00 civic's didnt have brackets welded to the frame rail like integra's and earlyer model civic's , the tranny side bracket bolts to the tranny . the mount bolts to the side of the frame rail , the driver side had a metal bracet that bolts to a two prong cast iron bracket that bolts to the block , and the metal bracet that comes off the cast piece bolts to a cylinder shaped mount that bolts to the top of the frame rail , the rear has a mount bolted to the subrframe and the motor is attached by a T bracket , and as i said in my earlyer post , you use the SOHC 96-00 tranny mount and bracket , driver side you use the SOHC mount and bracket but use the cast iron peice that bolts to the block out of a 99-00 si , and for the rear you use the SOHC mount that is bolted to the subframe and you use a T bracket out of a 99-00 SI ,shift linkage you use either SI or 94-00 integra,axles are the same thing 94-00 or SI ,wire harness just find one out of a 96-00 civic , as for a ECU use one that matchs the correct OBD as the wire harness you bought or buy the correct jumper harness and run a OBD1 ecu your choice ,cant get any more clear then that. also no matter what year motor you buy your going to have to use the sensors, injectors and distributor that match you wire harness.
radiaki11 is offline
Old 04-01-2009, 05:54 PM
b182boost's Avatar
b182boost has disabled reputation
good shit,thanks
b182boost is offline
Old 04-01-2009, 07:05 PM
radiaki11's Avatar
Originally Posted by b182boost
good shit,thanks
haha no problem man i broke the swap down for you in as much detail as i could and privided mount pics
Old 04-01-2009, 07:26 PM
that dude
goob's Avatar
goob has disabled reputation
if you need anyparts to finish your swap lmk i have alot of ek b-series parts....gsr hydro tranny....innovative solid mounts....the timming belt bracket....and i have a 96-98 engine harness...just lmk i might or probly have it...good luck with everything tho...
goob is offline
Old 04-01-2009, 11:19 PM
I <3 My DSM
SPAWN's Avatar
SPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud ofSPAWN has much to be proud of
damn man....+rep for you!!!
SPAWN is offline
Old 04-02-2009, 06:13 PM
b182boost's Avatar
cant get much better.....i,ll probably get w/you about those parts for the swap(goob)i need just about everything,except motor...
qualityauto
07-07-2008 03:20 PM
crzyman1994
Want to Buy / Trade ARCHIVE
25
01-22-2008 09:01 PM
Forged_b18c6
12-12-2007 06:17 AM
crzyman1994
11-21-2007 04:50 PM
Quick Reply: what would i need to swap b18 into 97 civic coupe?
