Turn signal noise
Old 03-05-2015, 09:09 AM
Noahhawk's Avatar
Noahhawk has disabled reputation
Default Turn signal noise
I have a 2000 honda civic si, which I recently hooked up 2 10in subs and an amp to. For some reason the next day my turn signal noise comes on randomly and then goes away and there is a red blinking light in the fuse box.. Any help would be appreciated. Thanks
Noahhawk is offline
Old 03-05-2015, 01:42 PM
VaDriven Mayhem
Lord Humongous's Avatar
Default Re: Turn signal noise
You wired it wrong. Try again
Lord Humongous is offline
Old 03-05-2015, 05:04 PM
I can't even imagine what you could have done to make that happen, because amps are incredibly simple to wire. You need 3 wires, one of which comes straight from the battery, one of which goes straight to the chassis, and the third connects to the remote turn on from the radio. How you mess that up I don't know, because there is only one wire which can possibly be wired wrong.
I don't think the noise is a turn signal, I think it's probably some other relay cycling on and off. Doesn't matter though, it shouldn't happen and you've obviously done something quite wrong.
Old 03-05-2015, 06:28 PM
VaDriven Mayhem
Old 03-05-2015, 07:21 PM
LET THE HATE FLOW
Yardjass's Avatar
Time for a set of madtyte Mike Hawk aftermarket turn signals, cuhhhhh!
Yardjass is offline
Old 07-03-2015, 03:03 PM
Too Old To Care
smilin dave's Avatar
smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave smilin dave
Did you run the wiring down the center of the car? If not, this is where I would run to avoid all other oem wiring, thus reducing the possibility of induced noise. Try also grounding all audio equipment to the same point using a star washer under the screw to insure constant ground. In other words, all grounds to a central point.
Regards
Dave
I know, no one has pissed me off yet. You only give enough info to hang themselves.
smilin dave is offline
Old 07-03-2015, 06:55 PM
Regards
Dave
That's good and very basic advice, but it doesn't sound like there's a problem with induced noise through the audio system....
Got those 15 posts though, so enjoy the classifieds!
bustedhatch88
02-25-2004 07:08 AM
94silude
02-07-2004 10:29 AM
DrkIrny
08-09-2003 08:27 AM
Quick Reply: Turn signal noise
