fuel management leads to....
Old 04-14-2007, 12:00 PM
sive ick's Avatar
sive ick is an unknown quantity at this point
Default fuel management leads to....
ok so heres the run down,just did the mpfi conversion on my crx and im running ona chipped pr4 which is chipped to dump more fuel for boost,now before i did this my motor was running strong and no smoke,now that i have it still pulling what it should but it smokes when i get on it.I average 40-50 miles on half a tank and about 110 on a full tank(taking it easy and mostly high way)
im not sure the color of the smoke but it looks a little grey with a mix of some real light blue,could this be because my cylinders are being drinched with fuel causing the oil to become fuel-fouled and burn off oil,im not losing much oil at all but when i change it its a light black/clear but feels like water and reeks of gas.....
so it that a sign of the ecu dumping to much fuel which i know its doing,or is this motor giving me the shits,it did none of this when it was still dual point
sive ick is offline
Old 04-15-2007, 05:28 AM
Sumospeed #O.G.
SlowLS's Avatar
Default Re: fuel management leads to....
Too much fuel, which probably fuel washed the rings. Need to put new rings in the motor. And get rid of that ecu.
SlowLS is offline
Old 04-15-2007, 11:33 PM
Don't get rid of the ECU, get it tuned. If it's chipped, it's all set to be tuned already.
Old 04-16-2007, 06:04 PM
Hi Skuuu's Avatar
Hi Skuuu has disabled reputation
It's my ECU, its an obd-0 PR4 ls ecu. It's chipped with a ebay chip....it's a trash ECU anyway.
and uh hahaha jared, hurry and buy a ecu. I need to give that to ben.
Hi Skuuu is offline
Old 04-16-2007, 06:22 PM
sive ick's Avatar
indian giver,btw its on a pm6 now,so no more smoke and i once again have good honda gas mileage i love it
sive ick is offline
Old 04-16-2007, 06:35 PM
Hi Skuuu's Avatar
hahaha, no i let you borrow it. I even told you that "lemme see if the ecu works" i said okay "can i just borrow it till i get a good ecu"
Hi Skuuu is offline
Old 04-17-2007, 02:08 AM
sive ick's Avatar
correction''you can have it'' "dont you need it" "no i got a pr3 now,that thing sucks''
sive ick is offline
Old 04-17-2007, 06:20 AM
Hi Skuuu's Avatar
haha either way, just let me have a ecu you dont need so i can give it to ben. I was going to give him that before you got it, cause I had his Pr4 in the hatch before i sold it.
Hi Skuuu is offline
hsbadazreb
11-27-2007 05:48 PM
gen4H22A
09-06-2003 11:48 AM
Vortech8pSI
08-28-2003 02:17 PM
ReVtecSi
04-15-2003 07:59 AM
Quick Reply: fuel management leads to....
