2004 Yamaha Raptor 660 + setup for sand drags
Means of contact: Cash
Price: $3500
Description: 2004 Yamaha Raptor 660
I am selling the ATV, +10” Sand Drag Swing Arm kit, and 727 big bore kit. I will sell the kits separately but would like to sell everything as a package deal. I also have a ton of spare parts that I will be selling as well.
I am the only owner and I am a professional motorcycle technician, this ATV has been well taken care of. Unit comes with a clean VIN and title.
The quad was modified for sand drags while I was living in AZ and is very fast. Although the 727 kit is not installed, the Edelbrock carb and HMF exhaust make a huge difference. I have reset all chassis settings back to stock and the unit can now be ridden anywhere. I had planned on racing it at Slades, but never found the time. This bike is a lot of fun and I will miss it.
I have tried to be as thorough as I can be with this listing, there is a lot. I will edit the listing as needed if I find more things as I clean out my garage. If you have any questions please feel free to email me and I will get back to you a.s.a.p. I have more pictures than what I can post here so if there is something you want to see let me know. Thanks for your time.
The ATV with following already done to it: Selling for $3200
Edelbrock Carburetor #EB-3026 $675
Carb was dyno tuned by Factory Pro while I worked at performance shop in AZ, has custom ground slide needle
HMF exhaust – Full system performance series with candy red silencer - $525
HPC ceramic coating applied to exhaust head pipes and mid pipe - $75
Moose Parking Brake Block off plate
Renthal Handle Bars with FMF Grips - $75
Gunnar Kill Switch Tether - $50
Lone Star Billet Axle Locknut Yamaha Raptor 660 - $99
Douglas Red Label Wheels - $320
Maxxis Razr Tires - $350 (when new)
Yamaha GYTR Shock Covers
Yamaha GYTR Water Pump/ Oil Filter Cover
ASV Clutch Lever, Brake Lever, Brake Lever Perch
New Battery
Engine Ice Coolant
Factory Yamaha service manual
Sand Drag Kit: Selling for $700
Skat-Trak Hauler Tires - $260(New)
Douglas Blue label Wheels - $100
Metal Tech +10” Swing Arm Powder Coated Red to Match Frame - $530
Billet Alluminum Axle Carrier - $200
Durablue Front A-Arms Lowering Kit - $105
Pivot Works Swing Arm bearing kit - $50
727 Big Bore Kit: Selling for $700
JE Pistons 727 Piston
Rings, Wrist Pin, and Circlips
New Sleeve already installed in cylinder—this cylinder has already had the machine work done
The Kit was $350 and the machine work was another $150
Kibblewhite Hi Performance Lightweight Racing Valve Spring Kit with Titanium Retainers - $180
Kibblewhite Black Diamond Valve - $180
Hotcams Stage 3 High Performance Cam - $200
Airbox with K&N airfilter and Billet adapter installed
*This kit requires cases to be machined to allow for larger cylinder to be installed. Not a bolt on kit.
Extra Parts: Make an Offer
Alba Action Nerf Bars(not pictured but have picture)
Thermostat housing and coolant hoses
Oil tank and lines
Coolant overflow tank and lines
Rear brake lever and perch X2
Foot Pegs with shifter
Right headlight
Front hub with brake disk
Right A-Arm and spindle
Tie Rods
Rear shock linkage
Axle
Rear hubs
Rear sprocket and sprocket holder
Rear brake disk and holder
Axle nuts
Rear axle carrier(bearings bad)
Yamaha GYTR “Carbon Fiber Looking” plastic engine covers
Cylinder head and valve cover with broken mounting lug, needs to be welded
Valve cover(useless without its matched head but has rocker arms installed)
Cases
Engine internals for lower end- transmission, counter balancer, clutch, etc.
Lots of bolts and hardware
These parts are things that I have acquired over the years. The engine parts are from another unit that was crashed and I helped part out. I never had the chance to go through everything real well and get cleaned up. The idea was to build a spare engine someday but that never happened. I cannot guarantee the quality of all parts but I will do my best to look at anything you may be interested in.
If you need anything from the spare part list, or would like to buy all of them outright, send me an email.
Pictures:
Price: $3500
New Battery
Engine Ice Coolant
Oil tank and lines
Right headlight
Tie Rods
Rear shock linkage
Axle
Rear hubs
Axle nuts
Cases
Pictures:
