LSV/B series parts
LSV/B series parts
Means of contact: Phone (757-812-5917) or PM
Im trying to sell my LSV setup. I will sell everything listed as a whole for $1000. Otherwise the price is listed next to the part. I am not really looking to trade for anything right now, but you're welcome to offer.
Specs on the LSV are as follows:
B18B/B16
~25k miles on engine rebuild
ACL bearings
New pistons/rings
New oil/water pump
Cometic head gasket
Golden Eagle head studs
GSR cams
Single belt crank pulley
Skunk 2 intake manifold
Omni 68mm throttle body
Phenolic intake manifold and throttle body spacers
Moroso baffled oil pan
New distributor
New NGK plugs/wires
PLM hytech replica header
New OEM vtec solenoid gasket
New OEM valve cover plug and gasket
If you want to buy things separately, prices are as follows:
Skunk 2 Manifold (For B16/ITR) - $150
Omnipower 68mm Throttle Body - $100
LS Cable transmission - $200
-High RPM 3rd gear grind when shifting quickly
OBD 1 VTEC Distributor - $100
PLM Hytech Replica header - $200
-Has some dents due to being close to the ground
Phenolic intake manifold/Throttle body spacers - $50
LSV Long Block - $500 (Long block does not include distributor, injectors, header, intake manifold
B18B/B16
ACL bearings
New pistons/rings
New oil/water pump
Cometic head gasket
GSR cams
New distributor
New NGK plugs/wires
