2.2 stroker GSR long block Kinsler itbs
Means of contact: 757-897-3fivefive6 (MAIN CONTACT)
Price: $5kobo
Description: 2.2 Gsr
Darton Sleeved gsr block bored 87mm
Eagle stroker kit
JE pistons
ESP h-beam rods
ACL race bearings
Type R oil Pump
Fluidamper Harmonic balancer
Arp Main Studs
Arp Head studs
Lightened fly wheel ( I have to double check brand an weight engine in storage)
All machine work done at Abacus machine shop
Port Polished GSR Head
Skunk2 Pro series valve train
Skunk2 Pro Series Flat face valves
Skunk2 Pro series Stage 3 Cams
Skunk2 Pro series Cam gears
Bisimoto Header
Kinsler itbs
Over the tube setup
55mm throttle bodies
Seimens Long Type body 65lbs/hr
Pictures:
I have some attached if you would like more photos just contact me
Price: $5kobo
Eagle stroker kit
JE pistons
ESP h-beam rods
ACL race bearings
Type R oil Pump
Arp Main Studs
Arp Head studs
Bisimoto Header
Kinsler itbs
Over the tube setup
Pictures:
94eg5squadMD
Engine / Exhaust / Drivetrain
06-21-2009 07:48 PM
89 CRX
08-02-2007 04:22 AM
