stator or rectifirier 06 gsxr 750
Old 03-20-2011, 08:41 AM
gixxer357's Avatar
gixxer357 will become famous soon enough
Default Re: stator or rectifirier 06 gsxr 750
Sunrise is gonna rape him. You should've hit me up first. If they haven't started working on his bike yet give him my number and tell him to hit me up.
gixxer357 is offline
Old 03-20-2011, 12:12 PM
trickyricky's Avatar
trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky trickyricky
Been calling him all day, I did see his bike there yesterday. He said something about an extended warranty. But I'll se him at work tomorrow and get the scoop from him. See the MotoGP race?
trickyricky is offline
Old 03-20-2011, 12:17 PM
gixxer357's Avatar
Nah....I was upstairs hanging curtains for the Mrs. Spent all morning in the garage bleeding brakes, changing oil and replacing my coolant w/ Water Wetter on both bikes so I did a little housework since she left me alone all morning....lol. I'll download it from Racing Underground later and watch it.
Old 05-25-2013, 01:02 PM
lshorts's Avatar
lshorts has disabled reputation
Originally Posted by gixxer357
For you I just might...lol
I need a stator and rectifier for my 2006 GSXR 750...Im in Delaware and the prices for those pieces new are ridiculous smh...Email me please at lshorts.dcusa@gmail.com if you can help me so we can set up an arrangement
lshorts is offline
Old 05-25-2013, 02:37 PM
Sheeeit
Hooch's Avatar
take a look at the plug and socket to the rectifier, open it up and check for corrosion on the pins, signs of a "burn out" etc. If so you can snip off the plug/socket and just mate the 2 ends with solder or something. you can also get your hands on a volt meter and find out if it`s indeed the rectifier or the stator. google will tell you how to check that.
Hooch is offline
Old 05-25-2013, 06:16 PM
Band
paperassgasket's Avatar
^^ that's easy.
First start the bike and check the voltage across the battery terminals.
Bike off - you should get ~12v
Bike running and revved over 2k you should get 14v (probably around 14v@idle too)
Now - to check the stator check the output wires (probably the yellow ones) for continuity to a ground.
if you have continuity between a power output wire and a ground, the stator is bad. If not, then your regulator is probably bad.
Check the wiring harness and connectors for burn marks too.
http://ricksmotorsportelectrics.com/...ier-regulators for a cheap replacement.
paperassgasket is offline
blackmkIIIsupra
06-30-2009 07:04 AM
D16er
04-23-2009 05:13 AM
sprayedcivic
12-27-2007 02:35 PM
nismo300zr2
04-30-2007 08:05 PM
Night Ryder
09-10-2006 09:37 AM
Quick Reply: stator or rectifirier 06 gsxr 750
