What exactly is a 3-angle valve job?
Old 10-17-2005, 06:11 PM
OG Alumni
BigBake's Avatar
BigBake is a name known to allBigBake is a name known to allBigBake is a name known to allBigBake is a name known to allBigBake is a name known to allBigBake is a name known to all
Default Re: What exactly is a 3-angle valve job?
Originally Posted by fc735
three angles on the seat instead of the standard 1. better flow of air of course, due to the smoother air transition.
not gonna do much on a street car, unless other things are done to improve airflow also.
It comes stock on a factory LS1 style head, I don't know how much more street you can get than that. You are correct that the airflow dictates the use of such small details.
BigBake is offline
Old 10-17-2005, 07:02 PM
ritz's Avatar
We all know LS1 heads > *
Hell LS1's in general > *
ritz is offline
Old 10-18-2005, 02:07 AM
Yup, jolly poopbuggy
Corey's Avatar
what kind of head? was this a performance shop?
They did it on nearly all their heads. The shop was not a performance shop. The did do some performance work (porting and sleeving)
It had been open for 80 years when I started working. Two of the machinists had been there for nearly 40 years.
Corey is offline
Old 10-18-2005, 09:06 AM
Iridium V
MGBRaceman's Avatar
MGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond repute
Something interesting that I've never seen before, Z1 motorsports offers a rediculous 14 angle radius cut valve job on their stage 4 motors, here's the link... http://www.z1motorsports.com/product...products_id=58
MGBRaceman is offline
Old 10-18-2005, 09:28 AM
The Pro to call.
HatefulMechanic's Avatar
GM started using it on production heads on the Vortech's in 94+, i figured they would use it on the LS's.
damn. my shop does a standard one angle on most unless i ask
unless they have changed their machine shop, which i think they did when they went to their new facility, i have seen quite a few problems with their engine work. again, i think they changed though, so i might be wrong on it.
HatefulMechanic is offline
Old 01-05-2012, 06:31 AM
mike93108's Avatar
mike93108 has disabled reputation
Royalty,
Since no one really answered your question properly, I joined this site to help out.
This is what a 3-angle valve job is....
A 3 angle valve job is the process of machining the contact area of the underside of the valve, so that the mating surface is smaller or sharper, and making the seat angle greater. This allows the valve to seal faster and more tightly. This also increases port turbulence, which increases air speed, allowing more air into the mix.
One reason why it is important to have a good machinist is that by changing the angles and size of the valve contact patches, you can change the “agressivenes” of the valve job. A more drastic valve job will have higher gains, but at a cost. Valves dissipate heat during their closed state. When the valve is closed, it is in contact with the cylinder head, and the heat is transfered. This issue with heat transfer is why titanium valves were introduced. Titanium valves provide ultimate thermal protection, and decreased maliability under stress.
Another thing to consider when doing any kind of cylinder head modifications is that entire valve train is designed to work as a system. The tolerances, valve lashes, spring tensions, etc, are all designed so that everything runs on harmony. When changing any part, you need to be careful and make sure that everything is compatible. I personally recommend the all or nothing approach. Many street cars will be just fine with stock head work. If you’ve got a spare head, and want to bring your car to the next level, i say go for it. But you can’t just throw in super aggressive cams, or get a 3 angle valve job by itself.
The best thing to do is make friends with a local machine shop. They will have more knowledge than you will know what to do with!
Hope this helps.
Be fast and true,
Mike
mike93108 is offline
Old 01-05-2012, 11:02 AM
I know this is a thread bump from 2005, so I'm closing the thread but leaving the post intact for now if someone can get some knowledge from it. Normally that would get an infraction or warning for bumping a 7 year old thread.
Old 01-05-2012, 11:08 AM
Oh, and titanium valves aren't used for their "ultimate thermal protection". They're used for their low mass. There are much better alloys for difficult thermal problems. There are special high temp Ti alloys, but they're used for the combination of weight and decent temp characteristics, not temp characteristics alone. There are a lot of nickel-based alloys with higher temp resistance.
sneakerfreaker
11-25-2007 08:15 PM
-Danimal
02-21-2007 08:29 AM
The real Ryan
03-22-2004 12:27 PM
geha13
03-09-2003 07:55 AM
Quick Reply: What exactly is a 3-angle valve job?
